mikeyss
Longmont, Colorado.
it said in my paperwork that one was replaced previous to me purchasing it and another was replaced when I had the new motor put in. otherwise probably wouldn't be able to tell
I have all the service records from the previous owner and they definitely were never replaced, lol. I guess I got lucky with a good batch of motor mounts made back in 09, haha.
shreksbrother
Auburn Hills, MI
A balmy 50° in the Detroit area... Gave it a much needed car wash. And I think I solved my issue of the engine temp not reaching 205°.
Sent from my Galaxy Note9 using Tapatalk
Regency
That's cool, nice install. Just for my knowledge, does your instrument cluster not provide temp and compass? I thought all NNBS did?
I think they swapped over to the instrument cluster after 09. I could be wrong though.
Tiki
Replaced coilovers and UCAs and found out it needs a new wheel bearing. Whoever buys it is going to get a lot of my free maintence monies lol.
St. Louis
Removed my hitch cover to compare it to the one I have from my 2011 swb before putting it up for sale and noticed my receiver is rated at 1000 lb tongue weight and 10,000 lb total weight.
I know the vehicle tow rating isn't that much, but is this the standard rated receiver that comes one these? My 2001 receiver is only rated 600 lb tongue and 5000 lb total.
2001 Yukon SLT
2012 Yukon XL Denali
2011 Yukon Denali RIP 5/20/18
For whatever reason the sticker does not mention the maximum tongue weight without a weight distribution hitch which is 600/5000.
Here's the sticker on my 2009:
St. Louis
Yeah, I'm used to seeing stickers like yours on there. My sticker seems odd.
Here's the on on my '01, although a bit hard to read, it's 600/5000 weight carrying and 1500/12000 with a weight distributing hitch.
2001 Yukon SLT
Well Tom, we know your Denali can tow 7800 or 7900 pounds maximum according to the manuals for your year. This might have been during the time the Japanese auto makers were publishing outlandish capacities for their vehicles.
I'm now curious as to why the 2009 and 2010 Yukon XL Denalis with AWD can pull 100 pounds more? And now see that the 2007 Yukon XL Denali AWD was rated for 7700 pounds.
Maybe they were using different u-joints?
93blkongreenpro
Went to go start the Yukon so I can pick up some wheels for my DD after this dr appointment and guess what, the battery is dead. It's been sitting since Thanksgiving, so I must have left something on. Its charging now.
I guess I will be picking the wheels up in the car instead, sigh. I really didnt want to put them on the seats and the tires are stretched and didnt want the barrels hitting everything.
Sent from my SM-N950U using Tapatalk
Derick
Indy Suburbs
I called a tow company and priced out a tow for the burb to my mechanic!
Horrrrrrible sounds at start up. Uneducated hypotheses are feeling like an oil pump...but I'm not driving it until I know.
Hi-psi
Atlanta, GA
Circling back to my adventure trying to over engineer a clean/easy way to do an oil change. LOL...
Anyone here ever used a fluid/oil extractor on their Tahoe/Yukon/GM fullsize truck for an oil change?
https://www.amazon.com/dp/B00LCEWR4A
I'm considering at least picking one up to make doing a fluid/filter swap on the transmission less messy since there is no drainplug on the pan.
HiHoeSilver
Away!
Chicago
You have a built in extractor for the trans service. It's the cooler line and the trans pump! I didn't spill a drop.
wwiizz
