I’m back with an Esky this time
Snowbound
Snowbound
Jim
Chicagoland (Lockport)
Not sure why it loaded so many times. Kept getting message saying it couldn’t load and then when it did, ended up more than once. For some reason I can’t delete the double posts. Any help is appreciated.
I’ll update later today when I get done working on this. Little slow going this morning, coming down with a cold and I can’t find my motivation. Coffee isn’t doing it, doesn’t help that it’s a crappy rainy day outside and I don’t have to work. Perfect day to be lazy. Thankfully I can’t find my cape or else I’d just be super lazy today.
Snowbound
Snowbound
Jim
I don't know why I've never made myself a brake. As I watched your vids, I recalled a handful of instances where it would've made a project much faster and easier.
Well, I gotta get a press first. :(
Or make one of them too while your at it. [emoji41]
Snowbound
Snowbound
Jim
Works perfectly, and nothing fancy=WIN:waytogo:
Thanks. Yep, simple quick and effective. That’s all I needed. Had to make a tire carrier for a CJ7 and need to bend some flat stock. Quick peak
Also put a 355 sbc in this heep. Still working on some rust repair and a full cage for it along with tube fenders. I have too many projects going on.
Snowbound
Snowbound
Jim
Finally made it out to garage after the wife was begging me to just stay in bed and just relax with her and watch some movies. As great as that sounded, I would have been kicking myself later because I have to work in the morning and she needs her wheels. My bones are aching and I’m run down but I need to keep moving or else I know I’m gonna feel worse later. Time to kick up the coffee a notch. Hope this helps, or at least maybe I won’t care how much I get accomplished today.
Here we go. 20 squats, some stretching, 20 pushups and 30 sit-ups is all I could muster. I’m going in.
I don't know about the mini workout, but the drink caught my eye! I love Rumchata!! Where'd you get that? You and me are the same--I could be sick as a dog, but I can't just lay in bed, especially if there's something that needs to be done.
Snowbound
Snowbound
Jim
I don't know sbout the mini workout, but thae drink caught my eye! I live Rumchata!! Where'd you get that? You and me are the same--I could be sick as a dog, but I can't just lay in bed, especially if there's something that needs to be done.
I think she grabbed that for me from Jewel. It’s pretty damn good.
Snowbound
Snowbound
Jim
I gotta get the alternator off and then the P/S pulley so I can swap this nasty looking bracket. I can’t stand the oxidation.
The belt tensioner wouldn’t move. The pulley bolt was turning, most likely stripped now. I had to use my big channel locks and grab the tensioner body to rotate it. When I did, it stayed in place. This is why I do this stuff. Little preventative maintenance goes a long ways.
I cleaned up the water pump pulley with wire wheel on die grinder and also hit the center of P/S pulley. Looks ugly but I’ll get it.
I always put some WD40 on the threads of my puller. It keeps from messing up the threads.
Let’s get this pulley off.
Now I can get the bracket off.
I have a lot of cleaning ahead of me. I’m gonna wire wheel, wire brush, scotch brute pad and maybe even some 1800 grit sandpaper to get this crap cleaned up. I’m not sure yet, but I may just go get a new water pump while I’m here. Wish I had time to blast and paint all this, but I don’t. Gotta get busy.
Snowbound
Snowbound
Jim
I’ll update in detail 2mrw. I just had a day from hell with this thing. Coil brackets didn’t work, power steering pump almost got doused with gasoline and set on fire, and I only got drivers side plugs and wires done.
Gotta jump in shower and hit the bed. 4 hrs until I have to get up and go to work. I’m beat and my whole body aches. To be continued........
Snowbound
Snowbound
Jim
Wonder why it's so crusty. I'm in Jersey and I don't think mine looks that bad, or rusty.
I’m not sure, the chassis on this rig is pretty clean. But I see this a lot on these LS engines. My LT1 in my 94 Formula has these lines on the back of the heads and they were bad but didn’t look like this. One of those things that make you go hmmmm.
Snowbound
Snowbound
Jim
Haven’t had time to update yet. I didn’t forget, just have to get this valve changed out on a tank here at work and then I’ll fill you in on what happened yesterday.
Snowbound
Snowbound
Jim
Work nightmare behind me now so I can take a minute and explain what happened.
I spent some time with a brass brush and scotch brite pad cleaning up the oxidized aluminum. Also hit the power steering pump with wire wheel and wire brush.
I painted the P/S pump and water pump pulley with some POR15. P/S pump painted all the way around even the back and bottom. Made sure I got it cleaned and coated really well.
Then I removed the valve cover on drivers side and noticed my other cover is different. This one doesn’t have a PCV valve, just a nipple that connects to vacuum line.
I didn’t have a nipple or barbed fitting on hand that would work. Also my stash of grommets weren’t the right size so I spent some time and modified a grommet by slicing a little out of it so it would fit the thickness of the valve cover. Easy enough.
Then I took a PCV valve I had and cut the bottom off of it to gut it. Now it’s just a hollow valve and will allow cover to breath just like the original.
So I got the drivers side valve cover on with new FelPro gaskets. I bolted the nice coil bracket on the valve cover and then removed coils from factory bracket. Wrong bracket. The ICT brackets I have are for the small early style coils. Damn it! I should have paid more attention before doing all that first. I would have just ordered the correct valve cover and brackets to do it once. Now I’ll have to go back and change coil bracket when I get the new ones. Whatever, at least that side valve cover is done. The passenger side is the same as what I have cleaned and painted. But I’m not gonna pull coils and cover right now just to change valve cover.
At this point, it’s getting later, probably around 6:30-7 and I have to get up at 3am so I said screw cleaning the water pump, timing cover and passenger head. I just need to get the new bracket installed and the P/S pulley back on.
So, I apologize, I didn’t get any pics along the rest of the way because I was tired, pissed, sick, sore and getting progressively more aggravated by the minute. You’ll see why.
Went to put P/S pulley on and the threads inside the shaft were cruddy and rusty so I sprayed it with some brake cleaner and blew it out. Then I chased it with a 3/8-16 tap. Put my installer on and it went about an 1/8” and pulled the threads out of the shaft. I used a mirror and could see some threads still there that I didn’t hit with the tap or the installer bolt. For some reason my bottom tap was missing and my 3/8-16 thread chaser is broken so I had to cut my regular tap so it would bottom out and clean the threads. That was a *****!! You don’t want to put a lot of heat in it or it will get brittle so I used a hack saw.
I get the hole tapped and it looks good. Get installer back on and start cranking to push pulley on and it pulls all the threads out of it. At this point is when I’m ready to just pour gas on this thing and set it on fire and go to bed. I had to take the pump off again and I drilled out the shaft out which was another PITA cuz I have to hold the shaft with a pair of hog jaw pliers while trying to drill straight. Then I started tapping it for a heli-coil and the tap broke off in the shaft. It’s too late to go get another pump (9-9:30) so I spent a good hour chipping at the tap and trying to back it out with needle nose, snap ring pliers, screw driver, a big f-ing hammer, I’m beyond aggravated now.
I get it out and use another tap but went really slow, in 1/4 turn, back it out, spray it with lube, in 1/4 turn, back out and repeat until I get it threaded. Install heli-coils and try again. Install pump back onto bracket and tighten bracket.
This time it went but it wasn’t going on without a fight. By the time I got it on, put on the alternator and tensioner it was 11:15. I threw my tools on the bench and went in to eat something, shower and get in bed. Got about 2.5 hrs of sleep then off to work I went.
Came home and finished off the passenger side plugs and wires, cleaned the throttle body and MAF sensor and put the air intake back on. Bout that time I had another vehicle come in. ‘13 Ford Flex with a complaint of no heat. It was low on coolant and water pump was sleeping out weep hole. No way I’m getting into this one. It’s a 3.5 with dual overhead cam and the water pump is behind the front cover and driven off the timing chain. Book time is 14 hrs. Filled it up, bled it out and sent it on its way. No thank you.
j_jerry79
