mfennema
I finally got mine back from the shop. They replaced the rear shocks under my extended warranty and it rides soooooo much smoother.
wendal
Dallas
I'm not on IG. What is his name there?
Sent from my ONEPLUS A6003 using Tapatalk
Eod1
If you see me running, I would try to keep up.
Phoenix Arizona
Just got done painting my push bar
NathanJax
Vacation Nathan
Jax, Fl
Has anyone heard from @NORCAL SS ? I PM'ed him a couple days ago and haven't heard from him...
In his signature, it says call/text him 24/7 and even has his number. I text him back/forth a bunch...
You can call/text me 24/7 at 415 519 2432 or email me at [email protected] if you have any questions about lowering. My name is Tony and i'm here to help you out, and yes 24/7 means just that. If you see the parts for less shoot me a email and I'll see what I can do.
tighten gas cap message went away for 1 day came back this morning, so apparently I have a small evap leak when it's cold, this is going to be fun.....not
Wolfbraid
Winston Salem, NC
I have the same intermittent message...other than the annoying message and check engine light that comes and goes, any immediate harm?
no it's just epa crap, I have my tech2 i'll have to hook it up and see what it says is going on, I also need to probably replace a hvac sensor and probably a blend door actuator that was going funky in the summer but it didn't matter then because it was always hot now it blows cold in the back unless I hit the rear ac control even if it was already preset to 80deg
sarneson91
Alexandria, VA
Upgraded my Spyder headlights by replacing the lights from Spyder or Sonar or whatever to sylvania silver star ultras until the LEDs get here, also 6k daytime/turns just need to figure out this whole switchback thing. Doing some research and reading to try to figure it out better
Pulled the driver's door panel off last night in an O'Reilly's parking lot to get the window back up. Now I'm in the shop trying to diagnose the failure for the window regulator.
Put gas in it today and it didnt click off till it was full!!! Haha
Ugh. I filled mine up last night: $77 worth of 89 octane. I wanted 93 but it was almost $.50 higher. With the cooler temps lately, the 89 will be sufficient.
ASG-MikeS
