@Doubeleive @93blkongreenpro
Just for more info.
Why spend $200 or more on an AGM battery vs sub $200 on a regular style battery or alternative AGM brand?
I mentioned AGM type and pictured the brand I purchased, I have two of them under the hood, sears used to sell the odyssey with there own label on it but they went with another maker a few years back maybe 5 years ago, there are a couple other AGM manufactures out there if you can find one for $200 less I say go for it, the odyssey run close to $300 pretty much anywhere
93blkongreenpro
Just for more info.
Reliability. I have a little sound system and routinely will leave the truck in limbo playing movies for my son on the headrest TV so the added reassurance and it being a deep cell battery gives me some reassurance if I do happen to drain it.
I've regular batteries have shorter and shorter lifespans, some not even lasting 30 months and that's infuriating to me.
Sent from my SM-N950U using Tapatalk
Fosscore
Thx guys on this insight for me and others. Researching tonight and getting one in the morning. Wil update once it is installed.
A few rebates, % coupons and core charge that could make that decision and alter the end price a bit.
:Handshake:
kbuskill
NE. FL.
I know you guys don't care for Optima... and I am not trying to sway any decisions.. but I have had 2 Optima batteries... a yellow top in my old Esky and a red top currently in my Burb and have never had an issue with them.
As a matter of fact I bought both of them at a substantial discount from Advance auto parts because they were "used".
If someone buys a battery and installs it in there car and then it dies... because it was actually there alternator that was bad... they can bring it back to the store and Advance will replace the battery under warranty and sell them an alternator.
These "used" batteries get put on a charger, and once charged if they pass a load test, then they get sold as a "used" battery and sold with a 30 day warranty.
I cannot tell you how long it has been since I bought a NEW battery.
If there is something wrong with the used battery it will surely shows it's head before 30 days. I have never had to get a used battery replaced under warranty.
Back to your regularly scheduled programming.
Some people try to knock them but I have ran them for a solid 10 years and I run a 4000 watt stereo system and the volt meter doesn't even budge when it I turn it up, no light flicker, never had a problem starting, they will outlive the warranty.
The story on Optima’s that I’ve heard is that in the last 2 years something changed and they’re not built the same way or something along that line and the new ones have issues. It’s all over the internet that the new Optimas are crap.
kbuskill
NE. FL.
There may be something to that.... mine were/are older obviously.
mwilliams
Olive Branch, MS
Got some wheels
93blkongreenpro
It's been longer than 2 years. I had a red top in my old 93 protege from 7 years ago and it was crap. I had 0 awg big 3, 140amp alternator and 4 gauge to the trunk and the battery died in 2 years, mostly highway driving. Wouldn't crank a 1.8L 4 cyl. But a XS Power D3400 in and 4 years later, same alt, battery still pumping.
So this just happened. Grrrr.
Went out to clean up the corrosion on the positive battery terminal this evening.
While trying to remove the positive cable from the post, the post pulled out.
So I need a new battery now.
Thoughts about a replacement?
It had an AC Delco 48HPG, 660CCA. I have access to all the auto parts stores.
That battery has a 42 month free replacement warranty and pro-rated after that. I did not see the date code.
When I grew up down there, my uncle would have me go to East Coast Battery and Electric on 17th Street.
Drewphil
