Engine oil life monitor PID info
kbuskill
NE. FL.
I have been trying to get the engine oil life monitor to read properly in the Torque Pro app but haven't had any success.
These are the parameters I have currently...
And it reads 39% constantly.
I have tried many other configurations and equations but almost all of them give me a negative reading.
I know I can just pull up the info on my dash but I would like to get this working just because it should be possible.
Does any one have this working correctly???
Any help is appreciated.
I "think" I finally got the ethanol % working correctly... I should know tomorrow as I will probably fill up with E85.
I also have the oil temperature, transmission temperature, A/C high side pressure, and current gear working properly if anyone needs the info just ask and I will post the parameters.
kbuskill
kbuskill
NE. FL.
I am guessing I should have posted in the general section to get more exposure/potential feedback.
St. Louis
Here's what's in the PID info on my Torque Pro app
2001 Yukon SLT
2012 Yukon XL Denali
2011 Yukon Denali RIP 5/20/18
kbuskill
kbuskill
NE. FL.
2001 Yukon SLT
But the real question is..... does it actually work???
Have you compared the engine oil life reading in torque pro to your DIC?
St. Louis
Haven't really checked it or used that in the app because it's in the DIC.
I'll check it when I get a chance this week.
I have a Scangauge that's mounted in my 2001 and the oil life is spot on. I looked up the PID info on their sight but it's completely different fields/values.
2001 Yukon SLT
kbuskill
kbuskill
NE. FL.
2001 Yukon SLT
Any luck checking on this?
TJ Baker
Colorado
I can confirm that what gooffeyguy posted works for my 2005 Yukon with LM7. Matches my DIC and Tech 2 as well.
You mentioned having oil temperature? My Tech2 doesn't show that for my 2005 5.3 so maybe not available.
I recorded the traffic while displaying the data with the Tech2 as well but I haven't looked that over yet,, and honestly, I don't really know what I'm looking at there. Still fun though !
St. Louis
Just saw this.
No I haven't checked it yet. My brother borrowed the OBD bluetooth adapter to pull some codes the other day and he hasn't returned it yet.
2001 Yukon SLT
St. Louis
Got my adapter back. Oil life monitor doesn't give a reading in Torque app.
My adapter is the OBDLink MX and I even tried it in their app and I can't even find an Oil Life PID in the app, unless I create a custom one.
2001 Yukon SLT
kbuskill
kbuskill
NE. FL.
2001 Yukon SLT
Yeah mine doesn't work either. I can change some of the parameters to get a reading but it's not accurate.
Mine comes back with a reading of A = -1
Oh well no major loss.
TJ Baker
Colorado
="Yeah mine doesn't work either. I can change some of the parameters to get a reading but it's not accurate.
This has me curious. What year etc. Do you have?
I think I previously posted mine is a 2005 Yukon 5.3 .
St. Louis
I think GM changed to a different system (CAN bus) around '05, so PIDs that work on earlier vehicles are a bit different on newer vehicles.
2001 Yukon SLT
BG1988
the engine oil life is based on a RPM counter not the mile..
kbuskill
kbuskill
NE. FL.
It's actually based on a complex algorithm that takes into account many factors including mileage, RPM, oil temperature, etc.
James @swathdiver has posted about this before with more info.
BG1988
I did but don't remember right now. I'll check tomorrow if there's time.
the problem is not using the correct oil..
most will pay for the cheapest crap they can buy
and then whine why did my engine blow up or AFM failed/VVT failed etc...
2011+ requires SN minimum SAE certified (dexos 1) /SN plus(dexos 1 gen2)
2005+ requires SM minimum (but might as well go SN/SN plus for a few pennies more.)
read the label very carefully
even if it says dexos 1 it may not meet the SN requirement
since gen2 dexos is SN plus
it has to say on the label SN or SN plus.
500 miles 90% oil life
dizhai
