LED headlights in stock housings - My Install and feedback
RichardCranium
Mebane, North Carolina
There are tons of threads, some have tons of replies. I really researched this forum for several days, it was really hard to find any conclusive feedback on LED's. I pondered between Spyder headlights and a projector retrofit, I even bought $400 worth or Morimoto to retrofit my stock headlights......but the biggest drawback and handicap to us all is the lack of adjustment, not being able to really dial in and aim our headlights properly. I gave up on the bi-Xenon retrofit, I didn't want to JB Weld the projectors in place......which would have been necessary for proper alignment.
So, here is my thread with OEM replica housings and LED low beams. I have always been a critic of LED's in stock halogen housings. We've all been blinded by many different makes and models with this setup. I decided to try it, since I didn't see a lot of folks giving feedback one way or another about them in our headlights.
Low and behold, I've never been flashed by oncoming traffic with these LED's.......there is a distinct beam pattern with our OEM headlights. It isn't astray and distorted, like pretty much every other LED/reflector setup on the road. It has a similar pattern to the stock halogen bulbs, similar distance/visibility as far as the projected area goes......just much brighter and much more useful. No more driving down the road with what feels like candlelight, with the dim and yellowish halogens. Nice bright white, and much better illumination.
My setup:
Ebay link to OEM replica headlight housings from AM-Autoparts - I purchased a set of these to retrofit the bi-Xenon setup. They are great quality and fit well. For $100ish, they can't be beaten. Even if you want to replace your faded/foggy headlights, its worth the money. New headlights really make your vehicle look a ton better.
Here are the LED bulbs I went with - You'll find LED's range from about $40 to well over $100 for a pair. I was happy with the feedback on these, and ended up buying the anti-flicker harnesses with them also. You can fit these in your housings with no modification! You don't need to trim the core supports like you would with other brands. Speaking of, I actually have clearanced my core supports already for the bi-Xenon, as it was necessary with how far the projectors protruded out of the back. I can clearly see behind the headlights though, and there is plenty of clearance with no modifications needed.
You do the math, I am in new headlights with LED low beams installed for about $200. Win win win.
Pics are attached. If anyone would like to see anything specifically, let me know.
20180830_234150.jpg 20180830_234215.jpg 20180902_182007.jpg 20180902_182128.jpg
GranPrix
You wouldn't happen to have any pics of the halogens up against your garage?
Bucky1
I ended up going through Amazon for some Auxlamp LED replacements. They were obviously brighter right from the get-go. But they seemed to be aimed lower somehow. So my distance vision was actually worse. I raised the aim of the lights, and it is an obvious improvement in night vision over stock for sure. I was concerned that I would be blinding others. But as of yet, not one person has flashed me. For the $50 spent, this seems like an obvious improvement that was worth it.
GranPrix
Yea a side by side I think might sell it, at least for me.
Change one side back to stock (whichever's easiest) and snap some pics. I like the "one side stock, one side LED" comparisons in addition to the full "before" and "after" pics.
RichardCranium
RichardCranium
I'll try to toss in a halogen tonight after I mow the grass, then I'll get a garage pic and pull it out in the driveway to get a comparison shining on/in the garage.
RichardCranium
RichardCranium
Pics coming, got the drivers side swapped back to a normal H11 halogen bulb. If this doesn't convince anyone enough I don't know what will. This is about 25 feet out, the camera/phone is about 3 feet off the ground. Ideal level for adjustment, so you aren't blowing out the passenger car's mirrors in front of you at a stoplight. You can't even tell the halogen is doing anything, the LED is so bright.
RichardCranium
RichardCranium
Some of the headlight and the LED's, comparison to show the mounting depth. In the picture of the LED installed with just the back end showing, you'll notice my core support that is clearanced for the former bi-xenon Morimoto projectors.
20180904_193550.jpg 20180904_193541.jpg 20180904_193631.jpg 20180904_195255.jpg
kbuskill
NE. FL.
Ryan Buck
Mesa Arizona
I just took out my led bulbs and bought a set of 100watt and a set of 80watt HELLA halogen bulbs because everyone was saying how badass they were and super bright.I’ve put them in and turn them on and couldn’t help but to laugh they were probably worse than the factory bulb I took them right back out and send them back and get my money in return
Ryan Buck
Mesa Arizona
When these guys talk about retrofit.... What the **** do they even mean? LOL and what’s the point
sanco
Chicago
looks great on pics but is it a pure white light or a foggy/blueish LED light. sorry I don't know how else to explain it. My biggest issue is that with some of these retrofits the light output is foggy I guess you can say. The OEM ones are very crisp in comparison.
Just wondering on that color output.
RichardCranium
RichardCranium
Do these have the adjustable collar???
My Supernova V3's do not.
I can check the documentation that came with it, I'm not sure.
Not picking on you, don't take this the wrong way. But you mentioned replacing your stock bulbs and being disappointed. A retrofit that you see folks referring to is taking an aftermarket projector housing (the Morimoto I used was the size of my fist) and modifying the stock headlight to make it work. Check my thread where I tried this and ran out of patience with lack of adjustment.
https://www.tahoeyukonforum.com/threads/2010-tahoe-hid-retrofit-installation-thread.99033/
It is white, and I mean WHITE. From every angle I've looked at it from the outside and from driving it, there is no hint of blue. I was actually a bit concerned about this as well, but the temperature rating seems pretty accurate on these.
sanco
Chicago
Hmmmmmm I might look into this, I've been thinking about either researching for a decent set of bulbs or just ripping apart the housing and doing like an led retrofit using some jeep parts
RichardCranium
RichardCranium
I am also looking at these:
https://www.amazon.com/dp/B077BT6M6...cfd7c39b45e5d0da7ec37f376598fd&language=en_US
With some of the reviews I've watched they are saying these are a bit better.
I'd be interested to hear feedback if you go with them.
Some food for thought on this topic: I tried 2 sets of headlights, so 2 full rounds of splitting a headlight pair and getting alignment right. The first set I did, I set up the projectors absolutely square. In my HID retrofit thread, I documented well with photos. I actually drilled out the H11 bulb socket to accommodate the threaded end of the projector, so I drilled right into the conical collar that surrounded that H11 socket. That is how I know I was absolutely square with the install of the projector. Turns out the projectors already aim much lower than the stock reflected halogen setup, so my lights were so low they couldn't be adjusted up high enough to be useful. That crippling factor again, the lack of good adjustment in the stock headlights.
My second set of headlights, I drilled through the H11 socket with much more of an angle, what I thought would put me in a good position to adjust appropriately. Turns out I went too far, as I am surprised I wasn't distracting aircraft or sending signals to the International Space Station. At that point I had some folks on here trying to help, as they had been there before. The only way to get the projectors perfected would be to JB Weld them into place. This is when I lost my drive to finish the projector, and landed me where I am.
These LED's are nothing compared to a true HID/Xenon setup with quality projectors and components. I will be up front and honest about that. I just couldn't bring myself to "hack" it together with JB Weld, its kind of against my own pride to use that crap......guess that is what turning wrenches for a living for 15 years did to me. :)
GranPrix
Obviously not as good as HID but better output than halogen right?
sanco
Chicago
Thanks for your input, I was thinking more along the lines of getting a jeep led headlight And trying to make it work in our housing, but then again if I'm doing all that then why not hid instead...sigh... decisions decisions. Your write ups are great btw!!
Towmaster
