Tahoe Owner From Hell Paso,TX
So finally installed them. Old one were just broken while removing them and the new ones where a pain in the ass to install. I guessing the plast-dip was to thick for the tabs to go in, but what assn improvement it has made.
Love that blue;)
bottomline2000
Dallas, TX
What did you grab that out of? I've never seen that before.
My truck has that center console cubby/cup holder. Who would have ever thought someone would want to swap for that part, but I do like how simple it is. Probably find them in LS models.
915_Tahoe
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
SO AWHILE BACK I PURCHASED A PIONEER STEREO WITH SPEAKER COMBO FROM WALMART.
CAME WITH HEAD UNIT 2 6x5 SPEAKERS AND 2 6x9 SPEAKERS. I INSTALLED ALL BUT THE 6x9'S AND LEFT THE REAR ALONE DO TO THE 6x9'S WONT FIT. THE OTHER NIGHT I MODIFIED THE ORIGINAL SPEAKER BRACKET TO FIT THE 6X9, GOT IT TO WORK EVERYTHING CLEARS. I JUST NEED TO TRIM THE DOOR PANEL FOR THE SPEAKER.
20181230_172027.jpg 20181230_172035.jpg 20181230_173238.jpg 20181230_173244.jpg 20181231_141606.jpg
adriver
Using all caps is yelling or cussing on the internet...
This was already explained.
View attachment 213360 View attachment 213361 View attachment 213362 View attachment 213363 View attachment 213364
Not only is it "common internet language", but doing that slows down your reading. Its annoying as shit, and you're making it harder for people who are trying to help you. Instead of 915_tahoe getting it, they continue to do it in every post they make. If they didn't continue to do it after being informed of the problem, I would try to help them. Instead I'm just going to laugh at how stupid that was to mount your 6x9s like that. You would now be better off wiring them in series as one mono subwoofer.
SERIOUSLY, :ban:
915_Tahoe
915_Tahoe
HELL PASO, TX
Wow, a lot of negativity in here. The reason the caps are on is I post from work so the system is setup that way.
adriver
BULL …. SHIT... That's not the way systems or keyboards work. Amazing how you somehow figured it out for this post. Even on this post you could have just grown up and said OK. That maybe you didn't realize it was a problem or some other excuse. Instead you doubled down, and came up with another lie.
Or are you going to try to triple down and say your "system that writes in all caps", knows to use a small x when writing 6x9's, but not 6X9??
Or perhaps this one.
What I did at work yesterday , instead of doing my actual work. Lol
Where you didn't use caps, along with a couple other posts, but then later went back to it..
Clearly you're lying....
We need to get over ourselves?? You're the one who couldn't go-along to get the help you were asking for. I'll bet if I bother to search, this isn't the only thread someone has mentioned it to you. Were trying to help, and you are making it harder for people to do so. Not sure why that is so difficult for you to understand or for you to try to cooperate with the rest of the ENTIRE ******* INTERNET for the purpose of having improved communication.
We can keep this going or I can see that you have stopped using all CAPS for atleast a couple of petty posts. So lets see if we can just move on.
Where is Chicos tacos, and why is it so special? I just went through el paso a week ago. I fill up in el paso to and from Phoenix, because its about as far as you want a tank to go, and its the farthest West you can get Taco Cabana.
Also for the rear accessory panel, my plan is to install some USB inputs. There used to be so many different types of chargers, but now its really just Samsung and apple. Makes it easy to leave 1 or 2 cables back there (out of the way) for rear (or front) passenger charging. I was going to use a retractable cable and store it in the cubby slot.
915_Tahoe
915_Tahoe
HELL PASO, TX
When did I ask for help on this thread, cause I didnt.
IF THE CAPS BOTHER YOU THAT MUCH THEN DON'T READ MY POST SIMPLE AS THAT.
When caps are off I post from my phone.
WHEN CAPS ARE ON I POST FROM WORK, WHICH IS HOW OUR SYSTEM AT WORK IS.
915_Tahoe
915_Tahoe
HELL PASO, TX
So had a great haul this weekend @ the salvage yard.
for the HOE
Esky roof rack w/ cross bars
Esky shifter w/o the chrome cover (cover wasn't there when i took it off)
Both rear door lock actuators
Drvr rear door panel
Spare sub box
Drvr side inner bottom molding/seal strip
EBCM
for the Silverado
Drvr front door with window and regulator
Pass window
915_Tahoe
915_Tahoe
HELL PASO, TX
So i have done several thing to the truck just have not yet posted.
Whats new:
new set of tires for the stock 16's
full front suspension rebuild
front/rear shocks
new set on black head/turn lamps
L.E.D. tails
L.E.D. 3rd brake light
escalade roof rack
replaced driver rear door panel
replaced both rear door lock actuators
replaced the driver upper/lower leather covers also added a new bottom seat cushion
amp bypass
amp to power the upgraded stock sub
rear radio pocket delete out of a Buick rendezvous
bug deflector
removed fan clutch and shrouds
OE battery terminal covers
IN THE PROCESS AS WE SPEAK:
water pump replacement
OE updated thermostat w/housing
OE front main seal
added a OE harness from the fuse block to front of the engine
waiting on my ECM to arrive to re-install
OE e-fans going on
fuse blcok w/ provisions for e-fan fuse block
NEXT ITEMS TO INSTALL:
rear carpet with the tracks for the 3rd row seats
escalade shift lever
will gets pics up soon
915_Tahoe
915_Tahoe
HELL PASO, TX
What's your on/off temps? Can't wait to do this!! Where you put the oem relays and wiring? I bought the oem fuse box to do it.
Not sure on the temps, just sent it to the guy told him to turn then on.
Ran the factory harness as it would have been on the 05-06 models. Since mine is an 01 I had to use a relay for the ac, I purchased a novita relay and the matching pig tail to go with it. I'll get some pics of it in the morning. Also got the fuse box when I pulled the harness and fan from my brothers wrecked sierra.
Since mine is an 03, will I need a relay for the ac? I did get the complete harness including the relays--that 2nd half of the harness that attach to the fuse box-- from an 05.
BadDaddy2003
