Mysteriously using oil
MSharp71635
Has anyone ever heard of oil mysteriously disappearing from these? We have a 08 tahoe. Doesn’t smoke from anywhere, has good oil pressure but after a fresh oil change it gradually disappears. The first time I noticed this was when I changed the oil at the routine mileage one would change it at and it literally had a little over 2 quarts left in it.
It's not a mystery. The engine is burning the oil if there are no external leaks. Poor quality oil will cause it to evaporate. The PCV system was redesigned in 2011 to reduce the amount of oil that was being ingested by the engine. There is also a cover in the oil pan that keeps oil from spraying onto the underside of the pistons/cylinders. Worn rings will also consume oil.
How many miles? How does the AFM operate on it? Has it been overhauled?
M
MSharp71635
A little over 120,000 I believe, no overhaul, still has the AFM unfortunately. I did research the valve cover issue though and plan to do that ASAP. I’ll look intobthe oil pan fix as well, thank you so much
Is the motor regularly spun up to 3000+ rpms? Any smoke upon start up?
M
MSharp71635
When accelerating from a stop, does the engine regularly turn more than 3,000 rpms in 1st gear to get up to speed?
Mmmmmm I honestly can’t say for certain on that. I would say borderline 3000 possibly. Seems kinda of high for me I can say that but it’s primarily my wife’s car. She may get it up to that on acceleration.
What is the issue regarding that out of curiosity?
The higher folks wind them up, the more blow by through the PCV system which gums up the throttle body, intake manifold, etc. and of course uses up oil.
When my wife drives the truck, it comes back empty with the mileage tanked because she likes the way it accelerates. I don't often hit 3000 and use no oil between changes so far.
Mike L
I have a 2010 GMC Yukon XL Denali with 146,000 miles. A couple thousand miles ago it started randomly emitting thick black smoke from the exhaust upon startup. I couldn't find any cause/effect to it...seemed totally random. 2,000 miles ago I got an oil change and they said it was about a quart-quart 1/2 low. They filled it up, and the black smoke went away....until a couple days ago when it started backup. I took it back to the oil change place and asked them to check the underside for leaks. None found. They checked the oil level and sure enough, it was a quart 1/2 low. They refilled it and the smoke went away again. The guy at the oil change place said that most of these trucks start burning oil, and if was him, he'd just keep checking the oil levels and adding oil along the way to avoid having to pay for an engine tear down and rings replaced. But the funny thing is, my smoke was thick, BLACK smoke, not white which would indicate oil burning. Black smoke usually means too much gas is being combusted in the cylinder. Anyone else have this problem? I wonder why it goes away when oil is added, yet the smoke is black. ???
Conedaddy
