97audia4
Matched the front windows with the rest of the factory tint
93blkongreenpro
The ds front tire has a slow week. Been sitting for over a week in the garage and it's about flat. I will take it to the shop to see if it's the tire, or the rim. Had the tpms replaced already.
Sent from my SM-N950U using Tapatalk
Drok
Cold place in the north
Well ahh.... my rear leveling pucks....are ummm missing. The only reason i found out was because i heard an odd clunky noise yesterday and looked. Wonder if they came out when i went through the construction area an hit a stupid big bump that I didn’t know was more of a jump then a bump. Ugh this sucks.
Edit: looks like i may have the bottom coil of one spring bent too.
97audia4
5 hours into vacation and I found out someone left the lower rad clamp in the service position and it leaks all coolant out over the starter shorting it out .
93blkongreenpro
Thought the rad has busted?
Had to replace the rear brakes on her last night :(
97audia4
I wasn't sure which one it was so I bought the rad and the hose because being on the side of the road I didn't want to find it out it was one or other I didn't get. Ended up just being that hose clamp, I replaced the hose and both clamps with proper hose clamps so it won't happen again .
ASG-MikeS
