It's going as far up as it seems it should.If it's not going all the way up you need new gas shocks most likely.
Since i lowered mine 4/5 I have ran into it a few times.
They sell any length of shock you desire at your local auto parts, you'll have to look at the collapsed length and extended length as well as weight they'll hold up. I've done it with projects but never on something with mounts already installed. I myself don't even own a NNBS SUV so I can't be of any more help.Never heard of a longer shock but I’m interested if you locate some. My guess is off a a hatch that’s swings 90 degrees.
Awesome.Www.liftsupportsdepot.com is a good place to spec a bunch by lift strength, length, etc.
I forgot the NNBS have that. Probably wouldn't work.the power lift gate arm would need to be adjusted also not just the gas cyclinders
I think the first thing to try is to disconnect the arm and see if it goes up higher or not, I thought about doing it yesterday but I'm on vacation being lazy, lolI forgot the NNBS have that. Probably wouldn't work.
