Penz turner
- Joined
- May 22, 2018
- Posts
- 9
- Reaction score
- 3
I have a 2004 tahoe Full time 4WD, F4WD. 5.3. I have wheel hop and binding in the front when turning either way. The rear wheel break loose and front outside wheel leaves a black make on concreat. I have replaced upper and lower ball joint, upper and lower bushings, tierods, hubs, power stearing pump and lines, pitman and idler arms, stearing box, swaybar linkage. The NR4 transfercase has been rebuilt, front differential has been rebuilt, rear outer bearings and seals have been replace. My wife said she was driving and felt a hard clunk on the passanger side like she hit somthing but there was nothing in the road. Also when i turn left, even if tahoe is not moving service stability comes on in the DIC. No codes in snapon obd2. I will greatly appreciate all help.
