Wheel hop, service stability in the DIC when turning left
Penz turner
I have a 2004 tahoe Full time 4WD, F4WD. 5.3. I have wheel hop and binding in the front when turning either way. The rear wheel break loose and front outside wheel leaves a black make on concreat. I have replaced upper and lower ball joint, upper and lower bushings, tierods, hubs, power stearing pump and lines, pitman and idler arms, stearing box, swaybar linkage. The NR4 transfercase has been rebuilt, front differential has been rebuilt, rear outer bearings and seals have been replace. My wife said she was driving and felt a hard clunk on the passanger side like she hit somthing but there was nothing in the road. Also when i turn left, even if tahoe is not moving service stability comes on in the DIC. No codes in snapon obd2. I will greatly appreciate all help.
PG01
Up here to the right
Full time 4wd..Did you get new tires lately? They all need to match and be at pretty damn near close tread wear.
This is a drive line problem and not a suspension or steering problem. Tires have to be the same circumference, tread depth, sizes, etc. as Pete said.
My memory hasn't been the best these last few days but it is my recollection that if the light comes on, there's going to be a code stored somewhere. If you're just using some basic scanner or not looking in the right places with an advanced scan tool, you're not going to see them.
P
Penz turner
The differential in your transfer case is not allowing the front axle to slip, move independently, of the rear axle.
Is that the plabetary differential assembly you are refering too? I was told by the mechanic that it was fine, some barrings, shifting fork, lock up shift assembly, and oil pump were replaced.
All three differentials are the planetary style. My earlier post referred to the one in the middle as that is where I think you should start and then check the others. You don't live in Florida by chance do you?
P
Penz turner
No I am sorry to say I dont live anywhere near flordia. I see a High/low planetary carrier assembly and planetary differential assembly in the NR4 transfercase.
That's the one. Now which of those two inside the transfer case I do not know. I was seeing if you lived close by and could hook up my Tech2 computer to see what the computer is seeing and pull codes.
P
Penz turner
I wish i was closer. I appreciate your help.
Chubbs
Does the skidding happen only when turning left?
@swathdiver He lives close enough, I don't see why you couldn't send him your tech2 for diagnosis, pending the shipping charges or a small returnable deposit. Could help determine the depth of issue. Personally, I would narrow the problem down to abs, front diff or TC before jumping through the hoops that is the auto repair industry. I'd hate to think the TC is on the fritz after the rebuild he paid for.
P
Penz turner
No skidding and binding is when turning either direction.
P
Penz turner
Update, i took it to our local chevy dealership and a friend of mine, who is a mechanic there, hooked up their tech 2 and it showed 0 codes. Their most experinced mechanic came out to see what we were doing and he told me it is a bad sensor. He said that it could be my wheel speed sensors, which are new and operate fine when i have the snap on obd 2 scan tool hooked up. Or the speed sensor in the front of the transfer case, which there is only 1 sensor in the back. He said the back sensor has nothing to do with it. He thinks the encoder motor is not releasing pressure when i am making turns, which is thinking i am sliding. I had to replace the clock spring, and I am wondering if my stearing wheel positiin sensor needs recalabrated or replaced.
Chubbs
oh boy. Rubber on the pavement is not a skid mark and the master tech of a GM dealership is referencing the encoder motor which a BW full-time is not even equipped with. what a clusterf*ck
All, if not most of the info you walked away with is null & void since 'GM Master Tech' is 100% shooting off about an AutoTrac NP8
Your nr4 does have a TC motor, but only with a couple of positions. Def no encoder or position sensor engineered for the use of a clutch pack
I'm no expert of FT trans case but I'm pretty sure it is not equipped with all of these output sensors, either. that mechanic is specifically referring to the autotrac setup and it's all generic opinions, which even you can verify by running a Google search on np8/nvg246 faults. But then again, not your application.
That 'tech2' was designed to tap into any sensor on the vehicle and display what it is reading, so either you don't have the sensors or they don't know how to use their tools. Had you been there inquiring about a PT TC, that tech2 in capable hands would have resulted in a diagnosis. you will prob learn more about your equipment if you put together proper keywords & search terms.
Weird, I did not get a notice for this. I use it too much to mail it out. He might need to take it to another dealer or a 4x4 shop.
mattbta
Frisco, TX
P
Penz turner
Eickybobby5050
