St. Louis
One or both of the cigar lighters can be converted with GM parts to a USB port which plugs into the back of the 2010+ radios.
20983937
20944422
Is there more than one USB port on the back of the radio, or do they share/split the same port?
2001 Yukon SLT
2011 Yukon Denali
Ejbarah
kuwait
2001 Yukon SLT
2011 Yukon Denali
Just one Usb port in the back of the radio.
you have two options:
you can change the bezel lighter to USB
or bezel charger to USB
Drok
Cold place in the north
Ohh so you have to take out the radio and add a wire for the usb. Not just swap out the ligher part for the usb one.
What about the lighter port on the rear radio. Same deal?
Ejbarah
kuwait
Yes for USB you need to change your cable don't miss with OEM one just unplug it from radio.
for the lighter cable it's not attach in radio its comes from wire harness : you can leave the lighter or change it to charger one with same wire come from lighter.
Good luck
Yesterday evening, took it to Dollar General to get some avocados, paper plates and swap the propane tank. I thought it looked good in the setting so I snapped a pic:
aflumb
Las Vegas
Well this happened sooner than I was expecting, but was also 3 years in the “making”.
Took the wife this long to find a set she likes. Not in brand new condition, they have some minor rash and they are 26’s. Just a little to big so rubbing is a slight issue. For the price couldn’t pass up the deal
aflumb
Las Vegas
Since I woke up at the crack this morning I figured I’d get better pic of the ride
Also been having an issue with a water sound. Filled the overflow a couple weeks ago and It went away till today. Added more coolant and noticed it was leaking. Time to pull the overflow bottle
guy from norcal
Check the heater hose fittings at the firewall. Cheap plastic that will eventually break.
aflumb
Las Vegas
Yea there’s a lot of plastic in the cooling system. But found a hairline crack in the bottom of the tank. Going to get a replacement in a couple mins
koomie98
