Beginning rebuild on Escalade LQ9 motor
02EscaNate
02EscaNate
Trying to figure out the best way to unbolt the heads from the y pipe underneath. The bolts are pretty well seized, so I don’t think there’s going to be an easy way. Debating right now if I want to invest in a torch, or just stick a 1/2” impact gun on it and hope for the best. I soaked them already with wd-40 and used my smaller impact, and they didn’t budge.
You should be able to break the bolts with a 1/2" impact. Also , when you're unbolting the bell housing bolts get some really long extensions, like 3' worth. You'll need them for the top bolts.
bottomline2000
Dallas, TX
I hope you are referring to the rust ********* wd 40.regular wd40 isn't going to do it. A 1/2 impact should do it after soaking the bolts.
02EscaNate
02EscaNate
Yeah, it’s wd-40 “blue flame” or something like that. Supposedly it breaks through rust better. I’m just worried about snapping the bolts off, but I’ll cross that bridge when I come to it.
Nashoba
South Central Oklahoma
Yes, WD-40 has a rust penetrant that works quite well, actually. I had a pair of rust-locked side cutters that I could not budge loose so I bought some of the WD-40 rust stuff and let the cutters soak in some of it. It worked and the cutters are functioning like new, almost. I was impressed. Don't know that it works any better than the good old 3-in-one anti-rust version, though. The only advantage is that it is easier to get way back in there with the WD-40 "spray" feature.
RST Dana
OH
Even if the bolts break off, it is no big deal if you are replacing the heads anyway....
05alive
Masshole
I think he might mean headers, as those would be what connects to the y pipe.
Heat the bolts with a bernzomatic, that should do it. If an impact and mapp gas won't do it, just cut it. You can replace the parts for relatively cheap.
02EscaNate
02EscaNate
Well, slight update/change of plans for this one. I still might be rebuilding this engine, but, we were able to track down a junkyard LQ9 that is getting swapped in for the foreseeable future. Engine has 50k less miles than on the old one, and I have a fairly short commute so it should last a while.
My mechanic doesn’t need the engine that’s coming out for a core return, so I’m considering hanging onto it for a rebuild in the garage. Will definitely be a long term project, but at least I’ll have the truck back on the road for now.
02EscaNate
02EscaNate
Going to go ahead and continue fixing up the Escalade. New engine runs like a champ (and actually better than the old one..) . My guess is the valves needed adjustment before one finally let go, because this engine is much smoother. Our mechanic replaced all of the engine gaskets before dropping it in, so hopefully those will be good for another 100k+ miles.
Moved onto the headlights next. I thought about polishing them, but the plastic that holds the bulbs in place was basically crumbling away. I went ahead and bought some new ones from 1A auto and...wow what a difference.
View media item 27279View media item 27280
00'BlueSteel
Carolina
Glad to hear it’s back and running better than ever, and those headlights look great really brought the front back to life. Did you get to keep the old engine for a long term rebuild?
02EscaNate
02EscaNate
I had the option, but would have had to pay the core charge in order to keep the old motor. I was tempted, but ultimately saved the cash to put back into the truck in other areas. Plus my garage is pretty short on space as it is.
Awesome news, and those headlights make a HUGE difference.
dizhai
