Front Wheel Bad Bearing and Hub?
YukonCrazy
Raleigh, NC
2008 GMC Yukon 5.3 flex 2WD 175,000 miles.
I have been feeling this vibration from the front of the vehicle for sometime now. It's not an alignment problem. I jacked up the driver side front wheel a few minutes ago. Putting my hands at 9 and 3 on the wheel there is a small amount of play when wiggling on the wheel.
Does that point to a bad wheel bearing and hub assembly or something else?
HiHoeSilver
Away!
Chicago
How about 12-6?
HiHoeSilver
Away!
Chicago
Putting hands on 12 and 6 and wiggling, I do get some play also but I would say a bit more play with 9 and 3 if that makes any sense.
12-6 is the hub, 9-3 is the tie rod (or other steering components), as a general rule of thumb. There is always a "little" play in the steering. 12-6 should not move at all.
YukonCrazy
YukonCrazy
Raleigh, NC
So I am going to revise my results. Jacked up both sides, one at a time. There is definite movement at 9-3 on both driver and passenger side, but nearly no movement at 12-6.
On the 9-3 movement, you can slightly hear metal to metal contact when wiggling.
A little more at 9-3 makes sense if your tie rods are a bit worn but like @HiHoeSilver said, there shouldn't be anything noticeable at 12-6. Most likely your hubs need replacing, and afterwards check 3-9 again to see about steering components.
YukonCrazy
YukonCrazy
Raleigh, NC
Could this be a bad ball joint?
Replacing the hubs a do-it-yourself task?
Would worn hubs or bad tie rods cause a vibration when driving?
YukonCrazy
YukonCrazy
Raleigh, NC
Really not looking forward to a trial and error on replacing parts to find the actual problem.
You can take it to a shop for an estimate and they should be able to diagnose it for you, then tell them you need to wait on the repairs. Sometimes there's a small charge for this, sometimes not. Then replace the parts yourself. Of course if it turns out to be steering components you'll end up needing an alignment afterwards.
jz57
Open wheel ABS sensor hole, fill some grease inside to eleminate wheel bearing suspicion
vibration is more likely to be the tires or possibly worn suspension, the tie rods are pretty easy to do and not expensive at all, but like mentioned above you will need a alignment immediately after doing the tie rods. I would start with the tie rods and alignment, have your tires checked out re balanced and rotated if still good tires. I wouldn't move on to the wheel hubs until you have eliminated other more common problems first.
Scottydoggs
NJ
while doing 12-6, look through your wheel and watch the rotor and caliper, caliper cant move, but the rotor is bolted to the hub, so if you see the rotor moving between the pads its a hub for sure. if its that loose you'll also get a abs light in most cases.
HiHoeSilver
Away!
Chicago
Everything up there is a maintenance item in my book. Especially on a truck with 175,000 on it. It's not really "throwing parts at it" as much as it is doing stuff that needs to be done anyways. Or just throw some c4 under there and call it a day.
YukonCrazy
YukonCrazy
Raleigh, NC
Every so often when backing up from a parked position while turning the wheel, I hear a single click from the front end. I wonder if that is a symptom of a bad tie rod end.
al2fast
Wisky
I had some shuttering at highway speeds that I swore was rims/tires. After exhausting that route I just threw the kitchen sink at the front end, lower ball joints, upper control arms w/ball joints, & tie rod ends. When I did my front struts w/springs about a month ago I did the end links. I have 118k.
From Rock Auto:
$38 ea for Moog Lower Ball joints
$76 & $77 for both Moog upper control arms with ball joints
$20 ea for Moog Tie Rod ends
$5 ea for new axle nuts
I have an AWD Yukon so I couldn't get a good idea on the bearings. When I pulled it apart my passenger side bearing made noise and sounded like it was lubed with a sand based material, drivers side felt OK. I said F it because I had it pulled apart and ordered up wheel bearing/hub assemblies @ $120 each. Those were the expensive parts.
Had to have a shop do the alignment after.
Really smooth now. If you are 2WD you won't even need the 36mm socket and axle nuts for the front end and if after you determine you need wheel bearings you don't have to pull the front end all apart because you don't have a driveshaft in the way of the bolts to get the hub/bearing assembly apart. I'm in Wisconsin so my shit was rusty and it took a good few whacks with a hammer to get the old bearings/hub out, but I bet you could get them out with a slide hammer if they needed encouragement.
For the lower ball joints I read up and watched some YouTube videos and I just pulled out my grinder and ground a ton of metal off of the lip of the factory ball joints and whacked them with a hammer and they came out. I bought a $50 ball joint press on Amazon that I used with my impact to put the new ones in and it was easy as pie.
Due to mine being an 09 and seeing salty Wisconsin winters the mounting bolts for the upper control arms were seized in. I didn't have a week to try and break them loose so I ended up paying the local guy $100 to do each control arm and I got charged $50 for new mounting bolts and alignment cams, he happily installed my parts. Good thing is worse case scenario and you cannot get them out you can still drive it to the shop.
Tie rod ends are stupid easy, it will take you longer to get out your tools and install the new grease fitting end in the tie rod end and grease it up than it will to swap them out. I just figured at my mileage and having a leveling block (which in theory places more stress on the upper ball joint, right?) that I would do both if I was going to pay for an alignment and then I saw how inexpensive the lower ball joints were so I went for the gold.
Sorry, long post, go for it and replace all those worn parts, it's very straight forward and you could easily do it in an afternoon.
YukonCrazy
YukonCrazy
Raleigh, NC
Thanks for the post. Planning on replacing the tie rod ends this afternoon. Having the car jacked up with the wheel off will be a good opportunity to inspect the ball joints. Pretty sure the tie rod ends are original so they definitely need replacement.
Eickybobby5050
