New brake lines in, bleeder questions
Randy Whistler
Randy Whistler
Living the dream! I'm just not sure who's dream
In Hell, but I've got a Tahoe!
I was going to suggest new calipers, loaded ones, being you have to bleed anyway. If you were trying to save money, yes just bleeders but I cant tell you if the calipers are in the best shape. Honestly, easiest way is new calipers, more expensive but well worth it imo
Thanks!!
PNWMuseumman
Bow Ties Are Cool
PNW
I definitely recommend changing the calipers if you can afford it. I did all 4 on my wife's Denali last summer. (I did it because I it needed new pads and rotors any way and my new dad senses took over being that the denali is what my wife and 1 yo son ride around in all the time... One thing lead to another aaaannnddd... Fresh brake parts all the way around!) Anyhow, if you are questioning it at all, I say pull the trigger on the calipers, definitely get the loaded ones if you can. If nothing else, that's cheap peace of mind knowing they'll work when you need them.
I just bought a loaded ACDelco set ( includes pads and brackets) from Rockauto for $70 each plus core charge. That was for rears on a 2002. With the miles that truck has on it, it's probably time.
M1Gunner
Gainesville, Fl
So you’re talking about calipers AND wheel cylinders. So I’m assuming you have disc brake up front and drums in the rear? If so, and you’re worried about breaker a bleeder off the wheel cylinders in the back. If they sat that long with out use they more than likely need to be replaced regardless. Wheel cylinders are stupid cheap and easier than calipers to change.
PNWMuseumman
Bow Ties Are Cool
PNW
Did they do drums on the back on the NBS? Both of mine have disc all the way around, so I just assumed all of the nbs had 4-wheel disc.
I just checked Rockauto and the 2000 Tahoe has drums in the rear. I did not know that. So...rear cylinders are less than $10 each so you can replace those easy and cheap. I hate drum brakes so much that I just did a budget conversion on my 08 Silverado and installed NBS discs in the back so I'll never have to deal with drums. But you can replace the rear cylinders if you want and the front calipers.
PNWMuseumman
Bow Ties Are Cool
PNW
I'm with you, drums suck... I see them only as a necessary evil on my 67' mustang... And that is only because I don't want to drop the coin on the conversion kit. Next time it needs brakes I may just bite the bullet and do it though.
Randy Whistler
Randy Whistler
From my recollection, which is up for scrutiny, my Tahoe has discs on the rear. However, since I was hitting my head regularly under the truck replacing the brake line, my memory may be a bit askew. . . . . . :confused:
I agree, if it's drums, no question, cylinders for all! If it's discs, I think the calipers will be the way to go. Now I just have to go look under the Tahoe's skirt and see what's back there. . . . :oops:
Should be discs in the front and drums in the rear. Business up front party in the rear. Like a mullet lol.
bottomline2000
Dallas, TX
My 2000 has calipers in the rear.. never seen a nbs with drums. That may be the OBS one..
My 2000 Z71 was drums, but it was OBS. I don't think I've seen them on an NBS.
I guess that's why they list rear drums and rear discs for 2000. I didn't even realize there was a 2000 OBS. Live and learn.
Randy Whistler
Randy Whistler
Went and looked, my 2000 LS has discs on the rear as well. From what I understand, it is NBS, so that might explain something. It was very confusing when I first tried to figure it out. . . .
Now I just have to see if it's single or dual pistons, yank them off and get the new ones. Sounds pretty simple after everything I went through with the brake line!
PG01
Up here to the right
2000 was first year of nbs except for z71, escalade, denali etc....those were still obs...im 99.99% sure of that.
'99_Tahoe LS 4WD - AZ
Phoenix, AZ
Hey, all, I'm so sorry to jack this thread, but I have run out of places to post this and I think this might be the best place. This has to do with upgrading the rear drums on my 1999 Tahoe 2-dr 4WD to discs...a job I had done last week.
So, here is the list of the things I did, in order, to my Hoe reference to its brakes:
1. Upgraded the front discs to Powerstop with bigger rotors and calipers (2014)
2. Converted to the Hydro-boost braking system (hydraulic instead of the old vacuum) (2015)
3. Installed a rear drum to disc conversion kit (last week - July 2018)
4. Upgraded all of the old rubber brake lines to braided steel lines
Now, here is the issue I am having. The shop that installed the rear discs could not get them to bleed. They stated they would need a specific hand-tool computer to instruct the ABS system to bleed the brakes. They stated they did not think the new rear brakes were "grabbing" and it was "a hydraulic problem, not a fluid problem." So I had the truck towed to my local dealer, as I was afraid to drive it (I did get in and stepped on the brakes while the engine was running and the pedal was mushy and went close to the floorboard, and the red BRAKE light was lit on my dashboard.
So, I went to my local Chevrolet dealer and they were able to bleed the brakes. They stated there was not enough pressure/fluid going from the ABS module/EBCM to the rear calipers and there was nothing else they would or could do. They did suggest I go to a local speed shop (Lopers) to see if they would install an automatic proportioning valve to get more pressure to the rear disc brakes.
So, I went to Lopers and they said the dealer was full of shit and they would have to entirely remove the existing ABS system from my Tahoe and "re-plumb it" to the tune of about 2000 dollars. Yikes!
So, here is my question: I have to believe there is an easier fix to this than what I am hearing. For example, in 1999, Chevy had disc brakes all the way around on the OBS Suburbans and 3/4 ton and larger pick up trucks, with four-wheel ABS and I have to assume they worked fine and got pressure/fluid.
So, basically, what my system is now (with the exception of the stock EBCM and ABS module/pump) is what was in a 1999 OBS Suburban or 3/4 ton or larger pick-up truck. Is it just a matter of upgrading my EBCM and ABS module (I have a Kelsey-Hayes system) to what is in the 1999 Suburban / 3/4 ton truck? Or am I fu**ked? I need info and options, brother. Please help!!!!!
CountryBoy19
Southern Indiana
Have you checked part numbers and diagram for various brake system components? IE., is your abs module the same as what is in the vehicles that came with 4 wheel discs?
Randy Whistler
Randy Whistler
As mentioned along the way in this thread, I had to replace my line from the ABS module under the driver side, and had to replace both calipers on the rear axle - neither bleeder would unscrew - break, yes, but not unscrew. I should note that, while running the new brake line, the ABS and master cylinder both did not hold their water, and had to be refilled when the line was in.
Once the calipers were replaced, bleeding was not a major issue. No reengineering, etc. Since yours is somewhat modified, this may not help much, but bleeding the lines and calipers weren't anything special, exciting or unusual.
I know this may not help any, but as long as the lines were in good shape, I've never had any major brake bleeding issues on any vehicle.
Phoenix, AZ
Thanks very much for this, Randy....very helpful! I now have the correct ABS module, MC and reservoir as well as the right hydrobooster and hydrobooster pedal ready for install. I'm going to have them installed next week and I think this should do the trick!
bluekenworth
