Drivers windshield washer
GranPrix
My washer fluid on the driver side wiper dribbles out. I’ve checked for cracks and leaks but I don’t see any. Does anybody have a way to check for any clogs or any other issues before I start tearing this thing apart?
It might just be clogged with something. Does it leak anywhere along the lines? How's the other wiper? Dribble out, or does it come out normally? Try disconnecting the line from the bottle and the wiper and blow some compressed air through it. Just might blow out whatever is clogging it.
GranPrix
GranPrix
Left side works perfectly, right side just dribbles out like a newborn baby
Ksnell
West Monroe, LA
Take and pull the little rubber hose off the cowl it has a plastic spike that sticks up. And see if it blows water straight out. Then u will know the clog is on the wiper end
The way it is Plummed it feeds the driver side first then flows to passenger
kbuskill
NE. FL.
Well I took the nozzles and hoses apart at the "Y" split on the arm. No clogs but it flowed just fine. Blew air and water through the the nozzles and hose with no issues. Put it back together and now it works fine... o_O
Gremlins.... lol
bottomline2000
Dallas, TX
My passenger side does this. Blew compressed air thru it amd it seems to flow fine....not sure what is wrong. Drivers side washes the car next to me lol..
Edit- this thread motivated me to look at mine again. I disconnected the hoses at the y connection next to drivers fender. Shot compressed air thru each nozzle..go figure a piece of dried rtv shot into the rag covering the loose hose. Both sprayers working normal again...a cheap attempt to fix the previously cracked washer motor came back to bite me lol..
kelseybear
Broke this plastic spike clearing ice away how easy is this piece to replace
Teeroy78
Winnipeg, MB, Canada
Thanks for this thread folks! My passenger side has suffered from almost non-existent flow since I bought the truck. I just lived with it since the driver’s side usually sprays far enough to make up for it. ;)
Come some warm weather I’ll give this a shot too.
rossida
