2007 tahoe droping gas tank
sick1166
is this an easy 1 man job and some jack stands I got charcoal clogged in my lines, or is there an easier way like a shop vac?
HiHoeSilver
Away!
Chicago
Its not too bad if you run it down to E first. I backed mine up onto ramps. Remove the spare first. Pull the relay and crank it a bit to relieve pressure. Watch a couple youtube videos to learn when /where to disconnect the harnesses and lines. I had a retainer clip for one of the straps break, so it might not be a bad idea to grab a couple ahead of time jic. Once you get her coming down, put a piece of plywood on your Jack to lower her. You do need to lower it rear end first, and then reach up there to disconnect some more stuff, so the plywood helps support it as you go.
TejasPitt
