Gear swap
MCAT069
So I have a 2004 4x4 2500 Suburban with an 8.1L 4l85e and 3:73. I also have a now dead 99 C3500 that has 4:10's in it. Would it be possible to use the 4:10's out of the '99 in my '04 Suburban? Attached is a picture of the RPO codes from the potential donor truck and its VIN is1GCGC33R9XF098096.
Scottydoggs
NJ
id think the 2500 is a 14 bolt rear, and the other one is a 10 bolt. so a gear swap its self likely wont work. the axle swap would leave you with 8 lug wheels on the 14 bolt axle too.
MCAT069
MCAT069
Here is a picture of the potential donor. Its 14 bolt too. The suburban has 10.5 rings, does anyone know how to determine what the 99 donor truck has?
M1Gunner
Gainesville, Fl
Is there a 6 bolt flange behind the pinion flange on either rear ends?
From what I’m reading the 10.5 has a 6bolt flange behind the pinion and the 11.5 does not.
6speedblazer
i want to say the c3500 trucks should have an AAM 11.5" if my memory serves me correctly.
moto
