Burnswil
Eleventeen degrees in Georgia for the last week or so. Want to keep this crap up your way next time?
It’s warming up here. Only going to be -4 for a low tonight!
NGAneer
NWGA
Need some help here guys. Front passenger side sway bar bushing is split and I need to swap it. As usual all my bolts are rusty and my impact is weak, don't want to snap it off and I've sprayed it for three days with PBB and still nothing. Gonna try a getting a torch to the nut on the backside of the frame bracket in the next few days.
All that said, anybody conquered this problem before and want to give some tips?
NGAneer
NWGA
That just ain't right. Its gotten over freezing once in a week here. This ain't right.
if one breaks not a big deal drill and tap in a new one, there's nothing critical right there to interfere
guy from norcal
You can try a 50/50 mix of ATF fluid and acetone. Let that soak for a bit,and give it a try.
08grey
This happened to me an only heat worked. I broke 3 of 4 and had to torch out the last one. Don't us a impact use a breaker bar to where I made a hole in the frame by accident and had to use a nut to hold the bolt afterward. You will feel the bolt give, watch it cause they stretch easily. Once you have it moving then you can use the impact.
Sent from my SM-G950U using Tapatalk
93blkongreenpro
I think someone tried to steal my wheels then saw I had wheel locks???? I heard what I thought was a bad wheel hub, put upon further inspection...
Sent from my SM-N950U using Tapatalk
08grey
Oh damn. Thank God you caught it. Carefull they gonna come back prepared next time.
93blkongreenpro
MAN, I couldn't tell you when or where it happened, but that the only wheel where the lugs were loose. All but the lock nut. I may buy another set of lock nuts and have 2 per wheel. I have some temp open lugs pm there now until new ones arrive. But that wheel was LOOSE. im glad further damage didn't occur.
NGAneer
NWGA
Had this happen to me on my Buick years ago. Wheel came off, skipped over two lanes, hopped into a parking lot and totaled a civic.
93blkongreenpro
Mann, that sounds like a helluva ride
I had some ones "rigged" hood fly off in front of me one time and would have killed my passenger at the time luckily the corner of the hood just stabbed the window and deflected off, guy was piss ass broke, no insurance, I could tell there was no way I was going to get a red cent outa that guy luckily it was just a window, it was one of those final destination kinda things.
Pilot
Bloomfield, NJ * Lewes Beach, DE * Buenos Aires
this is why I put an aftermarket alarm in with tilt sensor, glass sensor, etc.
What kind of alarm do you have? Do you have a mobile alert device? I'm really nervous about wheel/vehicle theft and break-ins. Thinking about getting an alarm with tilt and glass sensors but have heard a lot of bad reviews about the mobile alert devices.
I have a viper 5906v with smart start cellular module, gps tracker module, tilt sensor, glass sensor. it is a color oled fob with 1 mile range, viper phone app. I can be in Africa and start my car here, lock, unlock, pop the rear hatch. I have had this system and the previous models since smart start came out and baring a couple of minor glitches (on previous models) it works great.
if the alarm is triggered it signals the fob which has sound and vibration, and sends me a alert thru the app and records the alert in the app. the only thing I don't like about it is the current fob buttons are very sensitive and will depress in your pocket if you have it in a pocket with anything else, it does have a keylock option which helps but it will still buzz at you if the buttons are depressed in your pocket. a little annoying sometimes till you move it a little but I'd rather that happen then go out to a ****** up truck because some tweaker had to have my dvd system or wheels. on my old nbs if they ripped out the system usually it would cost another $500 to have the shifter fixed on top of anything else. it's not cheap to have installed and there is a yearly subscription for the smart start but it's worth it to me. I had mine set to sound both the viper alarm and the truck horn and I have added a internal high decibel siren (somewhat like a **** alarm) so even if your dead asleep it will wake you up and half the neighborhood.
Escalade2007
