Burnswil
Eleventeen degrees in Georgia for the last week or so. Want to keep this crap up your way next time?
It’s warming up here. Only going to be -4 for a low tonight!
NGAneer
NWGA
Need some help here guys. Front passenger side sway bar bushing is split and I need to swap it. As usual all my bolts are rusty and my impact is weak, don't want to snap it off and I've sprayed it for three days with PBB and still nothing. Gonna try a getting a torch to the nut on the backside of the frame bracket in the next few days.
All that said, anybody conquered this problem before and want to give some tips?
NGAneer
NWGA
That just ain't right. Its gotten over freezing once in a week here. This ain't right.
if one breaks not a big deal drill and tap in a new one, there's nothing critical right there to interfere
guy from norcal
You can try a 50/50 mix of ATF fluid and acetone. Let that soak for a bit,and give it a try.
08grey
This happened to me an only heat worked. I broke 3 of 4 and had to torch out the last one. Don't us a impact use a breaker bar to where I made a hole in the frame by accident and had to use a nut to hold the bolt afterward. You will feel the bolt give, watch it cause they stretch easily. Once you have it moving then you can use the impact.
Sent from my SM-G950U using Tapatalk
93blkongreenpro
I think someone tried to steal my wheels then saw I had wheel locks???? I heard what I thought was a bad wheel hub, put upon further inspection...
Sent from my SM-N950U using Tapatalk
08grey
Oh damn. Thank God you caught it. Carefull they gonna come back prepared next time.
Redoak76
