Matt00 2003 Yukon build
matt00
matt00
Norman, OK
Cattivo
The Concrete Jungle
Do you remember what kind of paint you used? And could you explain your process for prepping, painting, and then drying time? Also can you still smell the paint in it?
Take a look at my build thread starting at comment #336 in reference to painting your interior...my best advice is don't do it...it stinks up the inside of the truck for a long time and looks cheap no matter how much you prep it
My 5 Alarm Hoe | Page 34 | Chevy Tahoe Forum | GMC Yukon Forum | Tahoe Z71 | Cadillac Escalade - Tahoe Yukon Forum
Murderhoe
Is that a black interior I'm spotting?! (sometimes pictures lie)
I painted the dash bezel and center console.. sanded. Primed. Sanded primed and painted smooth. But that's all the black I'm going. And I used auto paint with a paint gun... And let it sit out of my truck for a month to kill any smell it's a lot of work.. but if done right. Looks great
matt00
matt00
Norman, OK
So I know I said I was going to start the interior, but I found a deal that I couldn’t pass up. 17” stock 1500 wheels on 315/70/17. I got them on with very little trimming, just the plastics up front. Now it doesn’t rub at all lock to lock. I’m still going to throw a leveling kit on though because with the deep bumps in the road the back tires hit the bottom of the truck (not very safe, I know.). I’ll have pictures later today because we put them on last night when it was way too dark and I’m at school at the moment.
matt00
matt00
Norman, OK
I also received the Corvette Servo and put it in with a buddy and my dad. It was harder to do than people like to admit, but it was fun. It was fairly easy after we actually got the sucker in. It’s ridiculous how much it helps, and even with the bigger tires it’s still doing what I bought it for and that was a firm 1st to 2nd shift.
Yes the servo does help a bit with that 1-2 shift. Good to hear you're progressing.
Chubbs
I'm anxious to learn how the trans' will hold up to the upgraded servo. That sucker has some miles on it, gotta be real careful changing stuff up like that. I mean, I hope it works great and actually extends the service life. I just had a trans tech convince me to leave the original unit as it is. His advice made sense & I haven't been through enough TM to know what reaction each & every little upgrade has on corresponding assemblies/hard parts/clutch packs. Please update in a week or 2 of any useful or applicable info.
matt00
matt00
Norman, OK
After almost a week it’s feeling great. The only time it has a long shift is in the morning when it’s been sitting all night and I’m trying to rush to school! Once it gets heated up it shifts perfect. My mom has a 2012 Tahoe LT that’s very smooth with everything so that’s what I am gauging mine off of. Although it’s a firmer sorta harsher shift I love it compared to what it was.
But it hasn’t even been a week so by the time two rolls around I’ll give you more feedback.
adventurenali92
Big Bear Lake, ca
So I know I said I was going to start the interior, but I found a deal that I couldn’t pass up. 17” stock 2500 wheels on 315/70/17. I got them on with very little trimming, just the plastics up front. Now it doesn’t rub at all lock to lock. I’m still going to throw a leveling kit on though because with the deep bumps in the road the back tires hit the bottom of the truck (not very safe, I know.). I’ll have pictures later today because we put them on last night when it was way too dark and I’m at school at the moment.
What do you mean 2500 wheels? 8- lug rims?
Chubbs
I picked up on a thread @ another forum, pickup had 250K+ miles. swapped-in a corvette servo and lost the trans' not too long after. I asked him if the upgraded servo had anything to do with hastening the trans' failure and this was his response:
"Nothing noticeable right away. I'm sure my driving style sometimes and the tuning I did on it accelerated the issue over the couple thousand miles I put on it. Plus being a used transmission it's a toss up on how long it would last.
1st and 2nd gear pulls were just fine, seems to act up a little later on when going into 3rd at full throttle."
matt00
matt00
Norman, OK
That’s pretty scary actually. If I notice any thing I’ll probably end up pulling it and putting the old one back in, let’s just hope for the best.
Chubbs
@matt00
I just bought a 2003 'Kon back in April. The VERY first thing that I did was drain the trans', replace the filter and pan gasket, & refill the thing with what I thought was the best TF I could get: AC Delco Dexron 6, full synthetic. If you haven't done this, I suggest you not procrastinate. Don't flush it, but dump whatever drains with removing the pan, and refill with some high quality stuff through the dipstick. Personally, I had a bad gasket the 1st time & I lost so much fluid that I basically replaced most of what was left in the upper part of the system that didn't go with the original drain. But for the most part, you would reinstall your trans' pan with new gasket and removable drain plug so that you can do another drain/refill 2-weeks later or whatever.
The next thing I'm going to do is install a larger Trans' cooler. I don't tow but I drive in traffic everyday, and the weather gets pretty damn hot down here for at least 6-mo out of the year. If you keep your TF fresh and cool, the unit should keep on truckin' if you don't beat on it with 75% or more throttle pulls. They say hard downshifts to 2nd gear and re-accelerating will fu{k it up, too.
The way I see it, I want the original equipment to last the life of the vehicle. If I experience a catastrophic failure for any reason, well, I don't know... I'm 100% committed to prevent' maint
matt00
matt00
Norman, OK
@matt00
Well I didn’t replace it when I first got it, but I just HAD to when I switched out the servo. Long story short I started changing out the servo, raged a little bit, tried to put it back together and drive to work and the snap ring popped out! Halfway down my street all of my tranny fluid is leaking out so I shift it into neutral and walk her back into my driveway. That’s an easy way to drain your fluid I guess. Lol
matt00
matt00
Norman, OK
I washed it sunday and snapped some pictures.
Also installed the light bar that came in a few weeks ago.
The switch that came with the light bar broke, so I ran to O’Reillys and grabbed a nice little metal switch.
It’s wired through the dash bezel, and since I couldn’t find the drill I used gorilla glue to get it in there good. It’s a bit dirty so I’m going to have to find a way to clean that stuff of the front. But I am happy with it so far!
She’s starting to come together and hopefully I’m not slowing down anytime soon.
varminpoolteam
