Drok
Cold place in the north
No problem. Just an fyi but you may already know, dark paint is a pita(black especially ) and is more sensitive to wet sanding marks vs other colors.
If you do wet sand get a soft block or pad to wrap the paper around. Using just the paper folded can/will cause an uneven or deeper scratches.
Here's what we use, 3k grit 6" foam sand pad, 2nd link is the hand pad we hook it too.
https://www.3m.com/3M/en_US/company...A?N=5002385+8709313+8710644+3293223566&rt=rud
https://www.3m.com/3M/en_US/company...d?N=5002385+8709313+8710644+3293193970&rt=rud
Fosscore
More good info for everyone.
Thanks tips on dark paint. Not sure if I will attempt, but good to get this detailed info.
Do you guys use the
Perfect It system 1-3 polishes and begin with the extra heavy duty or the lighter duty rubbing compound?
Drok
No we dont , Ill have to get the info on what we use in the am ill post the pics of it. We get stuff locally from an auto supplier.
We do have some 3m wax and leather conditioner which i use on my seats haha.
Drok
Heres what we got on hand right now we are waiting on the med cut which would be the same as the super cut in the black bottle
05Single
afraid of the dark
Disclaimer: doing this can really mess up paint if not carful and not all scratches will come out depending on depth.
We wet sand with 3k grit then start to buff with heavy cut down to the polish, finish with a good wax.
Not every car and every scratch gets that much attention and work though. It be a long day haha.
I used 2k on mine, but it's even more dangerous than 3k lol. Followed by the same steps obviously.
Wouldn't recommend either for beginners.
93blkongreenpro
good luck did mine 2-3 months ago, came out real nice but some of the scratches reappeared later I worked them pretty hard too, this is a just a idea I haven't done it yet myself but some super fine sandpaper might do the trick and wax it up real good afterwards
I won't be wet sanding. Just claybar, compound, swirl remover, wax, sealer. I've see stuff go bad with wet sanding and this 11yr old paint still looks decent.
Drok
And thats after a purge of stuff we didn't really use anymore. We also have a locker full of interior cleaning stuff too. Haha.
So you think my truck would be spotless.. right??:oops:
techbiker
Up here you can fail inspection if your headlights are too fogged up like that.
Good job kyle.
Looking great!
Why don't automakers produce glass lenses anymore? Plastic lenses always start to fog up by years 7-8.
PG01
Up here to the right
Installed the cabin air filter retrofit, manage to only cut myself one time, lol, wasn't as dirty in there as I expected it to be
Yeah, mine is garaged and im never really around leaves or crud...plus it was a year old when i did it...
You near them fires man? If so stay safe and good luck...
no I am up north just south of Sacramento those fires are down south by Los Angeles, the fires earlier this fall were about an hour west of me, smelled smoke a couple days but that's about it, there is nothing to burn around me except grass it's mostly all farmland around here.
wwiizz
