HiHoeSilver
Away!
Chicago
Changed the oil and emptied the catch can...
I think there's a little less than last time. I'll have to check. Need to rotate still, will get it in the next day or two.
Topped off the coolant. Was maybe 3/4" low. Hope there's not a leak... Never been low before.
MINIz guy
Sent her off to a shop to drill out my EGR flange bolts that seized in there. Not happy my mechanical ability couldn't get it out...but hopefully the shop can do it right and do it quickly.
Fosscore
All my power windows seem slow and the driver rear had to be coaxed up last night with a few kind words before it started raining.
You can hear the switches and see the lights dim on the driver door when an individual switch is engaged. More so if trying to roll up both front windows at the same time.
I’m thinking the window regulator(s) might be failing?
Thoughts?
AC Delco or Dorman?
Thoughts?
AC Delco or Dorman?
Highly unlikely you have more than one regulator going out at the same time. Especially since you said ALL the power windows. You must have a power problem. As in maybe a ground problem?
Sevenevez
Arizona
Thoughts?
AC Delco or Dorman?
mine have always been slow. especially if the engine isnt running. like half way up they slow down evenly
Thoughts?
AC Delco or Dorman?
What does the electric gauge go down to while you're pushing the buttons? Maybe battery or alt.?
HiHoeSilver
Away!
Chicago
Thoughts?
AC Delco or Dorman?
Time for the big 3!!!
TheAutumnWind
Ugh i need a catch can.
Fosscore
Thoughts?
AC Delco or Dorman?
Going back my original post a few days ago. A few guys responded and thx. I had a chance to shoot a video in between the rain storms.
I started at the drivers side front and went clockwise to end up at the actual troubled rear drivers side window, which I originally posted about but did not explain well enough.
Engine is on. Down and up and you can hear the switch clicking each time I touch it on all the windows. So likely not the switches.
Bit of dimming and slight drop in the battery volts when holding the switch of one window or more so with multiple switches, e.g. both front windows.
Towards the end of the video you will hear the drivers rear window dogging it and very slow coming all the way up, even though it of course is only half way down.
I’m thinking that one regulator is going out based on the sound and lack of performance?
AC Delco, Dorman or other to replace?
Alternator and battery seems ok? Holds a steady charge and all other lights and functions are bright and steady.
Any further advice or thoughts are welcomed. Thx.
Sevenevez
Arizona
hmm.. not sure what that clicking was. but thats pretty much the same speed mine roll up. driver and pass same slow spped going up
PG01
Up here to the right
Regulator and id spend extra on better...(if you can call it that) regulator so ac delco. My drivers front on my ‘01 went out while still under warranty . No probs after that.
Fosscore
Thx man.
Sheesh AC Delco showing $105 for the regulator without the motor and Dorman $103 for the regulator and the motor on Amazon.
@Galante
You think I need both the regulator and the motor or just the regulator because it is going up, just very slowly?
ASG-MikeS
