Homelink Problem
Danny3737
I had to replace the my garage door opener and cannot get my new opener to pair with the Homelink in my truck. I erased the old opener by pressing and holding the 2 outer buttons until I got the quick flashing light. Then pressed the garage door opener button and one of the Homelink buttons at the same time. I'm holding the opener about 2" away from the Homelink button. The Homelink light flashes slowly, then goes out after about 2 minutes. I've tried pairing it with to all three buttons and did the erase code procedure between each attempt with no success
I even tried the rolling code procedure when you press the training button on the opener then press the home link button until you get the quick flashing light which I never get
I had no problem pairing it in the past and was able to pair the new opener with my wife's Sienna and daughters Highlander on the first attempts.
Looking for any tips or tricks to get pair up the new opener
Thanks
gtrslngrchris
Your homelink isn't compatible with the new standard assuming you got a new opener. You'll need the adapter for it which isn't super reliable and kind of sucks.
Danny3737
Danny3737
Your homelink isn't compatible with the new standard assuming you got a new opener. You'll need the adapter for it which isn't super reliable and kind of sucks.[/QUOTE
That's a bummer. Odd that my Highlander which is a year older was able to pair with it.
Danny3737
Danny3737
Way too many bad reviews on the Homelink bridge. I think I'll just crack open the opener and wire up a momentary switch that I can hide under the dash or in the console. Who knows, I may figure out a way to tie it into the old Homelink button. With the new opener, I can open my garage from a block away now, I couldn't do that with the Homelink.
gtrslngrchris
It'll work better than the Homelink bridge for sure but it's not been as bad as the reviews say for me. That said, it doesn't always work either but it's not the end of the world for me.
Danny3737
Danny3737
I decided not to spend $40 for the Homelink Bridge. After watching a few YouTube videos, I went to Home Depot and bought a $3.50 momentary switch and wired it to the opener. I hid the switch behind the overhead console. The range is much better than I had with the Homelink system. Anytime I need to change the battery, I just have to pull down the console.
1beershortofsixer
Folks had garage door replaced. Did not replace opener. Had same problem. Turn out turns out their Tahoe 2013 had the "LEAR" system, not home link. You tube video shows how to program. If you have three buttons with small green indicator light above each button, you have a LEAR. Little house imprint it's Home Link..may help?
Danny3737
Danny3737
Mine is definitely Homelink, my Sienna and Highlander are Homelink as well. According to the Homelink site, they changed the signal around 2011 and you have to buy what they call a "bridge" to make it work. So far, I'm pretty happy with my mod. I can activate my garage from twice as far as I could with the Homelink system.
S33k3r
Dallas, Texas
Dumb question, but I didn't see any reference to this: Is your opener a rolling code opener? If so, you skipped a step. After your Homelink learns the frequency, you have to have the opener learn the Homelink. Ours has a button on the unit that hangs from the ceiling. This is fresh in my mind because I just added our Tahoe and our Suburban.
Danny3737
Danny3737
I tried the rolling code procedure, it only worked on my wife's Sienna. The newer openers are not capable with older Homelink systems
Sam Harris
View attachment 180945 View attachment 180946 View attachment 180947 View attachment 180948
I did this yesterday. Even used the same GB switch.. Now, I can open / close the door from probably an 8th mile away..! :party52: View media item 27535
JasonW4141
