Back N Black
Houma, LA
Got some pics for ya. I painted the plastic trim by the cargo doors and the mirrors. made a difference in overall appearance!. I live in a dirt road.
That looks great man! I need to go paint up my frame now! The good thing, is that I can throw it up on the lift. The bad thing is, with mine being a 2 door, the sombitch is a PITA to put on the lift. It's wide, and the arms of the lift are too long to lift by that nicely frame exposed frame. Takes a bit of playing with it to get it right. As bad as putting the Hoe on the lift, my 2 door Wrangler is even harder to find good lift points on! :thumbsdown::rotflmao:
Creese99
Ocala Florida
Thank you! I've never put mine on a lift. I also changed the rear diff fluid, and oil change today. Saturday I changed 2 heater hoses and both radiator hoses with Gates brand hoses. And I painted the rear diff cover wth some good high heat paint.
99YukonSLT
Ohio
Swapped out nearly everything on my driver's door for new (door shell, regulator, mirror) in the past week or so since the regulator went out, the mirror has been broken for awhile and the door was getting pretty crusty at the bottom. Pulled all the body side moldings and scraped off all the double sided tape that was left, sanded down to the rockers and sprayed it with tan bedliner to mimic the OEM paint that was there and protect the body from future wear n tear.
jiggie
View attachment 179083 View attachment 179084 View attachment 179085
I didn't realize how far that hitch sticks out lol. Guess ill be scraping the roll pan idea on my burb. How hard was the rear bumper to remove. Looks good with that lower part done that color!!
jiggie
Pulled my side moldings and am going to remove the blower motor and clean the part in the dash for the ac to be colder hopefully and blow better.
offrdr
PNW
so, i did nada to my hoe, but i went and bought a 98 2500 burban.....time to make bigger! doesn't seem to wanna let me post pic. ugh.
jiggie
Well it wasn't hardly dirty at all. Doesn't feel like it blows any different but smells better and feels a bit cooler. Lost one of the screws for the blower motor but it doesn't seem to effect anything
KenpoFish
Finally got around to trouble shooting a/c issue. Low pressure valve was leaking. Trip to the Zone for new lp valve. Kit came with lp valve, 2 hp stems, and dust caps.
Replaced the valve, stem, and covers. A/C working fine now.
Everyone out there working out in the heat, make sure you keep yourself hydrated. Dehydration, heat exhaustion, and heat stroke are a *****.
DallasTahoe
Replaced my climate control this morning, the past week or so it was acting stupid so out with the old, in with the new... I swear it seems like my AC blows colder now! [emoji2][emoji1360][emoji1434][emoji1433]
99YukonSLT
Ohio
Not hard at all. I removed it a few months ago to refinish also and replaced all the hardware at that time. Even then, all the bolts came out by hand except one, maybe 2 at the most. It got the bedliner treatment too, just in black.
Creese99
Ocala Florida
I installed a power steering fluid cooler. Went to a junkyard last week and found an 2003 tranny cooler in really good shape. Should make the pump last a lot longer. Tomorrow will be a PS fluid filter, shoulda done it tonight but it's gettin late.
DallasTahoe
Ordered the stuff to wire in my second battery since I decided to run efans. I worked on the shroud for them and all I'm waiting on is the fans to show up should have it in and running in time for my trip to South Padre Island on the 10th
edonwheels73
I took out the original rear speakers in my 94 and cut the bracket to fit 6x9s today.
Sent from my SCH-I545 using Tapatalk
wwiizz
