NORCAL SS Kit info/tech on how to level the rear of a 2015 up GM SUV
curly
Ordered Tony's leveling kit this week for our 2017 Tahoe... can't wait!
curly
Got the kit today and just finished putting it on... easy install, took me about 1 1/2 hrs taking my time and triple checking everything. I would be ready for a test spin except for the $&@$& staple I found in one of the tires while taking them off. Quick trip to the tire shop for a patch and we'll be rolling. Thanks Tony!
gat0r
DFW
^ well quote isnt working for me...
i havent noticed any issues/impact w/ towing after.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
if you tow i have a helper bag set up i can dial in for you and will do better then stock
dtom05
I just installed this kit on my '16 denali xl, and love the look from driver side as it has about a 1/2" of rake. However, the passenger side sits an 1/8" lower than the front, also looks goofy leaned from the rear. I have lengthened the passenger sensor rod twice now, making no change. Yes I have both sides isolaters, spacers, springs in correctly, etc. What now?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Different spring rates are used in front.
So go to store
Get 3 inch long 10x24 machine screw
Cut off head
Replace rear autoride link
Done
dtom05
Different spring rates on each side in front? Front is exactly the same measurement, and I have added about a 1/4" to existing passenger side rod (turn counterclockwise ) yet made no change. In fact I think the drivers side may have gotten a 1/8" taller lol. How much longer does rod need to be to get 1/2" more ride height?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
No gm used different spring rates in front which can vary 5/8 of a inch from another spring in front.
Like I said in rear do what I said and will lift it up enough. You do not touch front links
01SLE
Am I right to assume this kit doesn't change suspension assignment? Or should we get an alignment after install?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
If you drop rear no you don't need to do alignment
dtom05
Ok, bought 3" 10-24 machine screw, cut head off and installed on passenger side. Now pass side lifted to 1/2" higher than front as I wanted, but drivers side is now 1 1/4" higher than front! I shortened driver side rod and it helped a little but still 5/8" taller on drivers side which is definitely noticeable. I checked measurement in other places too and it is definitely 5/8-3/4" difference. Also, compressor for auto level seems to run often now. Is there another adjustment? Seems to me the passenger side should be slightly taller to accommodate road crown, not the other way around.
dtom05
Also, before drop kit, both sides were level in rear sitting at 37 1/4". Could the rear track bar have anything to do with this? I think its bushings are vulcanized so maybe it is making it lean?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
i remove airlines so all air comes out of system and then check height. if truck is leaning (which 99 percent do to drivers rear) thats normal. You then can turn on the truck see where it brings it to
01SLE
NORCAL
I ordered one of these kits over a week ago and the order still says processing. Card was charged immediately. Can't get a response by PM or email. What's going on?
01SLE
It came today finally. I installed everything easily but it's 1/2" lower in the rear than the front and I'd really prefer it to be 1/2" higher in the rear so 1" higher than it is now. Can I raise it 1" by adjusting the auto ride links? Do I lengthen them or shorten them?
gat0r
DFW
do you have spacers in? the plastic ones or heater hose?
i had saved this quote from some other thread here:
The ideal length for the sensor rods end to end worked to 3 11/16".
For every 1/8 adj. on the sensor rods changes the height 3/4".
so lengthen the rod ~3/16"
01SLE
I used both top and bottom insulators and the spacer.
I measured all the way around, removed the rods, and lengthened them by 3/16" and the rear height didn't change one bit so that's concerning. I drove about a mile before measuring, does it need longer to compute? I guess I'll lengthen them again tomorrow and see if I can get it to move.
I might just be bottomed out on my rod length, my rods were only 3 5/16" after my adjustment tonight. I'll bump them up to 3 11/16" and see if I get a change tomorrow after work.
Merch619
