2016 Suburban LT Fog Lamps install with OEM switch
jeffk19426
Question. When I opened my fuse box under the hood, I actually have a fuse in
Hey guys,
I am having a bigger problem, my 2016 Suburban is not even wired at the switch, pin six blue-gray wire is missing, out of twelve pins at the connector there are only 9 wires coming in. I do have a blue-grey wire going in the switch at pin 10. Can somebody chime in and tell me how to go about this? Or should I just use the switch that came with the harness and run wires through the fire wall?
Thanks,
Did you every get an answer to your question about no wire in pin six? I have a 2015 Tahoe LT and am missing the same wire as well. Does this mean the new switch with the fog light button will not work? And that I will need to use a separate switch and run a wire through the firewall?
Here is a pic of the wires on the back of the switch.
Thanks,
jeffk19426
Hi All, I'm looking for some help. I have a 2015 Tahoe and would like to add fog lights as described in earlier post. I've run into a few challenges and need some help finalizing the wiring. I purchased a new headlight switch with fogs (GM 23187804), spyder fog light kit and 611T. My goal was to use the OEM switch verses the switch from the fog light kit.
When I checked my headlight switch connector the Blue/Gray wire is in pin 10. I assuming based on other post this is not an issue as pin 6 was for rear fogs. And finally I have no Brown or Brown/white wire in pin 10 of the BCM X5. So that means I need to run a wire through the fire wall. Problem solved. I have a wire now through my fire wall. I'll do a write up on that later.
So can I follow the original installation except to connect the BROWN wire from the 611T to the new wire I ran through the fire wall to the relay that came with the fog light harness. Or am I missing something.
Thanks
SmittysTahoe
Great Thread!!! I installed my new fogs but need to tackle to wiring next... I am not an electrician by a long shot so this should be interesting. :help:
nilleo
nilleo
Thanks
You should not have to run a wire through the firewall regardless; you can if you want, but it's not necessary.
Rdr854
Northern VA
I see mention of rear fog lamps -- which are bright red. Are our tail lamp clusters set up for this or is that only for export vehicles?
nilleo
nilleo
I've never actually seen them on a Suburban/Tahoe. I imagine it's for exports. The only cars I've ever seen with "rear fog lamps" have been European. All I know is that they're mentioned in the service manual.
Rdr854
Northern VA
We had rear fog lamps in Belgium where there were mandatory. Also, my US spec Volvos all had them. Rear fog lamps are very effective in the fog and I know that we get some dense fog in the US.
Rdr854
Northern VA
I think I want everything OEM. Is that possible? What is the cost (parts and labor to add it to my 17 LS?
Tahoen
Thanks for the great write-up Joel!!
What are your thought on adding power fold/turn signal mirrors?
Ruikee
So i found GM Part #22752195 on ebay and on amazon. Guy on Ebay, and another vendor on amazon says this part #is specific to the Cadillac Escalade. Im sure since you have used it, its good for the tahoe and suburban as well?
Tahoen
Bill, yes that part # works with tahoe! Also, you can get that relay at most auto parts store. I got mine from Advance Auto.
ja_rocc
Picked it up from AutoAnything. I can't comment on the quality of the lighting since I don't drive it, this is my parents' truck - I'm only the family tech :). The bulb is an actual bulb, my guess is the stock fog lamp bulb that it should be. I've seen other kits that have the bulb in the housing and a pigtail coming off of it with the proper connector; this one has the connector right on the bulb. Aside from the lens being plastic rather than glass, I'd say this kit is a pretty decent OE replacement.
Hello guys this is a great thread on the install. just got my 2017 tahoe 1 week ago and want to add fogs. I bought the spider kit that comes with a relay do i still need the 611t? should i use it on place of what came with the kit? where is my bcm located? i know I'm a little late to the party but any help would be appreciated
ja_rocc
Hey all,
I wasn't able to find many (or any) cases where aftermarket fog lamps were added to a 2015+ Suburban /Tahoe (or similar generation) with the OEM switch, so I created an account here to share for anyone else that's interested.
Let's get to it…
Tools you'll need:
7mm socket driver
10mm socket driver
T15 torx driver
Suggested tools:
Clip removal tool
Electrical tape
Wire ties
Parts used:
Spyder FL-CTAH15-C fog lamp kit
GM headlamp switch w/fog part# 22752195
DEI 611T
Preface
I was hoping to use as much factory wiring for this installation as possible to keep everything as “factory” as possible, but mostly to avoid doing more work than I had to :). I dug into some schematics to see what the factory wiring was like and then proceeded to look for all the wires in the truck before getting dirty.
The good news – the factory fog lamp fuse was installed in the fusebox from the factory, woohoo. Also, the wire from the headlamp switch harness to the BCM was present at the headlight switch and at the BCM. The wire from the BCM to the underhood fuse box for the OE fog lamp relay trigger was also present at both the BCM and the underhood fuse box, excellent!
The bad news – the wires that are supposed to go from the fusebox to the factory fog lamps weren't in the wire bundle going to the front grille where they're supposed to be. I investigated further and found that the wire isn't even pinned in at the fusebox, way to cheap out GM!
Here's where the wire should go, notice how pins are populated to the left and right of the pin we need, but not where we want one :(
This setback meant that I would have to run my own wiring from the aftermarket fog lamps to the battery, and a relay to to control it all. I'll still be using the factory trigger wire for the factory fog lamp relay and just use that to trigger my relay.
Reverse engineering
The factory front fog lamp circuit works as follows – when you press and release the fog lamp request button at the headlamp switch, this sends a ground pulse to the BCM. The BCM interprets this pulse as a request to turn the fog lamps on, and if the headlamps are on, it sends a ground signal to the underhood fusebox to the fog lamp relay. When the fog lamp relay clicks on, it sends power to the front fog lamps and there ya have it.
Since I don't have access to a programming tool to enable the fog lamps feature on the BCM, it didn't do anything when I installed the new switch, as expected. No matter, I brought the 611T into the picture to replace the BCM's role in this party. So the 611T will take the momentary pulse from the fog lamp switch and control a latching on/off ground output that I will feed into the factory fog lamp relay wiring. Since the factory fog lamp relay wiring is missing at the fusebox and I'll be using my own relay, I'm pretty much just hijacking this wire as a way to get through the firewall without running any new wiring.
611T wiring
Black – to BCM brown connector, Blue - pin 22
Green – to headlamp switch, Blue/Gray – pin 6
Red – to BCM brown connector, Red/White – pin 4
Yellow – to BCM brown connector, Blue – pin 22
Brown – to BCM brown connector, Brown – pin 10
611T wiring explained
The module is “active” when the Black wire is at ground and the Red wire is at 12V+. I wired it up so that it only has ground when the parking lamps are active so that the fog lamps can only come on when the parking lamps are on, and turn off when the parking lamps turn off. The Green wire receives the momentary pulse from the headlamp switch to control the MOSFET that the Yellow and Brown wires go to. The Yellow wire is looped over to the Black wire so that it only has a ground input when the parking lamps are on as well. Lastly the Brown wire is what will trigger the aftermarket fog lamp relay on/off witch each press of the fog lamp switch when the parking lamps are on.
Interior Disassembly
Remove the fuse panel lid on the left side of the dashboard – it's the large plastic panel covering the interior fuses on the left dash.
With that door off, remove two T15 torx screws from the side of the lower dash panel as shown.
Next, remove another two T15 torx screws holding the lower dash panel from underneath, they should be easily visible.
Optional – use a small flathead screwdriver to unclip the hood release latch and separate it from the panel. You don't have to do this, but doing so will let you completely set that panel aside once you unclip it from the rest of the dash assembly.
You should now be able to unclip the lower dash panel. There are about 3-4 clips holding it on now, just get a good grip and pull towards the rear of the truck. These clips can be stubburn.
Once you take off that lower dash panel, you should now see two 7mm bolts holding the switch panel in place. Take those bolts off and pull that panel off – again, pull toward the rear. There are maybe two or so clips on this one. Unplug the harnesses and swap out your switch then set the whole thing aside.
The switch is held on with these clips...
Exterior Disassembly
Start the engine and turn the wheels all the way to one side.
Remove the 7mm bolts securing the felt wheel-well cover on the front bumper.
Get under the bumper and remove two 10mm bolts and a clip holding the felt cover on from each side of the truck.
Reach in and remove four 10mm bolts holding on the fog lamp blanks. (the left-most screw is out of view in the image below due to the angle)
Put the new fog lamps on, turn your wiring up through the fender and into the hood area, and put it all back together if you'd like. Don't forget to secure the wiring with a few wire ties to keep everything tidy.
Wiring
Headlamp switch
Fog lamp request wire (Blue/Gray)
BCM
X5 connector with parking lamp (Blue) and fog lamp (Brown) relay activation wires and a decent constant 12V+ source (Red/White) for the 611T note: the fog lamp relay wire may be Brown or Brown/White, take note of which color it is for you!
Underhood
Trigger wire for your fog lamp relay, should be the same color as you found inside at the BCM
Just in case it's not exactly clear from the previous picture where that harness is, here's a more zoomed out shot...
Good 12V+ source for your fog lamp relay
Appendix
For your reference, here's a rough block schematic of some of the circuits discussed here.
And lastly the final product
All lamps on
Parking lamps and fog lamps only
Fog lamps off
Hey man great write up made me go buy a Tahoe lol! I got the spyder fog light kit which came with a relay so do I still need the 611T? Where is my BCM located? I definitely want to go the route you did any help would be appreciated
Ruikee
Thanks
Hi Jeff,
If i read this correctly, you arent looking for a brown or brown/white wire in pin 10 of the BCM, just looking for a brown or brown/white wire on the BCM X5 connector. I believe the pin 10 reference is from the fog light switch connector. Let us know if you got it working.
Ruikee
Yes you need a relay under the hood. The 611T will connect to the BCM connector. Pics are at the beginning of this post. I read that he just wire tied the 611T under the dash near the fog lamp switch.
Xavierflores73
Hi, someone around New York or Jersey did the installation?
If yes please send me a PM. Thanks
Hutch08
Anybody with the Vanquish have an issue with the supplied wiring harness?
I received my kit but the supplied harness seems to be way to short.
I could possibly have been trying to route it incorrectly, how did you guys route it?
Any other tips or tricks before I attempt the install? I'm planning on using the harness that's pig tailed so the fogs will always come on with the low beams.
Drewphil
