What is this plate on my oil pan???
kbuskill
NE. FL.
I am curious what this plate is on the oil pan of my 5.3L 2008 Suburban LTZ 2WD.
At first I thought it was some kind of inspection plate but from looking at pics of the inside of the oil pan it doesn't appear to have a hole behind it.
So is it some kind of "skid plate" or is it some kind of reinforcement for the cast aluminum pan? Or???
Just kinda curious if anyone knows.
kbuskill
kbuskill
NE. FL.
I'll bet that's a sound dampener.
Good theory.... If it had rubber between it and the pan I could definitely believe that but I have never removed it so I couldn't say for sure.
Can't really imagine having much noise from the pan though.
It would be cool if someone made a heat sink that would bolt up in this location.... Although it probably wouldn't do a whole lot considering the sump is further back.
02Lightning
It looks similar to a plate that is on top of the blower on my Cadillac. And I know that is for sound deadening.
kbuskill
kbuskill
NE. FL.
Well, I'm just glad to see that I am not the only one in the dark on this one... Lol
Brian Wilson
I do know I took 3 of the bolts out of mine. I thought it might be an access port for the oil pum oring. But no oil came out so I stopped.
Lol- access port. You mean like what GM should've included in the beds and floors of/ their trucks and SUVs from '87-'06 to access the fuel pump module?
Judging by the number of bolts, my guess on the plate mystery is that it has to do with reinforcement. The oil pan on the LS engine is a structural part of the bottom end of the motor and that plate is on a wide and otherwise unsupported area. Casting reinforcement ribs on the inside of the pan would impede oil flow back to the sump and casting them on the outside would increase the size profile. Maybe engineers measured dangerously excessive stresses in this area and this plate is all that was needed to sufficiently reinforce it while meeting a certain budget. Retooling to add threaded bosses to an existing pan design would be much cheaper than retooling for an entirely new pan design.
Just my guess!
Brian Wilson
I like my idea better. So if for some reason you are running without your engine cradle over rough terrain, and a sharp very soft rock hits that particular spot on your pan, the soft rock will shatter before it hits the much lower sump and your engine will be perfectly safe.
kbuskill
kbuskill
NE. FL.
Just my guess!
Just seems odd to me that none of the other LS pans for other vehicles have this plate, at least none that I am aware of.
I thought about that, but summed it up to product improvement. Maybe there were a few cases where the older design developed cracks? Like I said- it's just my guess based on what I see.
I'm not saying anyone here is right or wrong about what this is, but I just don't see GM going out of their way to invest money to alter an existing design and add parts just for the chance that someone out there among these millions of SUVs removes something then goes off-roading and then is lucky enough to hit a particularly soft rock that just so happens to not hit the much lower oil pan sump but also finds it's way around the cross member. By this logic, GM should install sweepers in front of each tire just in case somebody happens to drive where there may be nails because there's a much larger chance of that.
scottd
