Get a catch can before any mods.
metelhead
I've been off this board for many years, but I recently found my back to find solutions.
My 09' Tahoe has been steady, clocking in at 189k; traveling sales puts on the milage. But the 'Oil Consumption' has increased which I need to change...So I replaced the Valve Cover (but in the process received the slightly wrong cover (the pcv port was of a different design and the oem hose would not connect), so I took the next logic step and went Catch Can shopping (as this would ultimate solve 2 things; most importantly was replacing the oem lcv hose(s)...
However, I ended up with 'rectangle Catch can', the mounting hardware was bleak so I improvised some and made a bracket work..etc..and got it nicely connected and solved my first problem with the valve cover- yeah!
What I didn't expect was any performance at all to making the mod, but my Tahoe feels like the chains have come off and come to life- the response is quite noticeable, the sound is slightly deeper and it just wants to go....I know I must be psycho schematic...but either way I'm enjoying the new ride. That said it seems my old pcv valve/hose must have been doing more harm than good......
Now I want more... Air intake, tuned, big brakes and 2/3 drop....I knew I shouldn't have come here;)
redeknightjr
I am seeing different types of catchcans at catchcans.com. Can someone point me in the right direction? I have an 07 Tahoe. Thankyou in advance
1SG Retired
08HoeCD
Catch cans are great for catching oil blow-by in vapor form and condensing it into the can for easy disposal. I ran a catch can in my '12 Challenger, as the Hemi setup is known for allowing a ton of oil to collect in the intake manifold without one. However, there's no way that they alone will increase power/acceleration to any noticeable degree.
bottomline2000
Dallas, TX
Yeah I don't think anyone is saying it will increase power but it damn sure will help you from losing it. I just emptied mine last night and it had about 4oz of oil in it that would normally be in my intake, on top of the pistons, coating the plugs and going out the exhaust.. long term that would be a gradual and maybe not as noticiable loss..I know I have no plans to take it off.
Sent from my SAMSUNG-SM-G900A using Tapatalk
I'm thinking his old PCV valve was clogged. That could explain his perceived increase in power.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
So after reading many articles on forced induction, from what I understand is that for those who supercharge we technically don't need a check valve. This is because the pvc is before the supercharger so it never sees boost. If it was a turbo setup, the whole system would be under pressure so that when a check valve would be needed.
So we can run a catch can like everyone else. From back of driver valve cover to catch can to pvc port on blower.
bacin87
San Francisco, Ca
I'm with @Red Rocket. It would be hard to tell where the catch can went without lifting the engine cover, if they even noticed the catch can. I tried to make mine look as oem/factory as possible. Also why I'll be going with a airaid Jr. to keep with the factory look.
which catch can did you get? can you provide a link or name and model?
sumo
rhode island
Moroso.
93blkongreenpro
I got my Moroso in the mail and broke the nipple off the piece that goes in the intake manifold. How does that come out? I was following the moroso instructions and didnt realize until I got the the Chevy dealership that the tube comes loose from that piece. It will come in tmrw morning.
Sent from my SM-N910P using Tapatalk
bottomline2000
Dallas, TX
Damn James!! DAMN!! I don't think it does..not even sure why they would tell you to pull that off.
93blkongreenpro
You can order it separately, so it SHOULD be replaceable.
The instructions says to detach from the valve cover, then swing to the front and they have a picture of the entire unit coming up and out of the intake.
Granted, 10 years and 96xxx miles later of heat. But not once has anyone said not to attempt to pull that out. Or no one has tried to pull it out but me. Dam.
FatDog
Picked up a catch can for the Escalade from catchcans.com and just finished with the install. Super easy, straight forward and quick install.
4" piece of 3/8 hose
4 each 3/8 clamps
couple zip ties
and presto!!!! Didn't even finish my beer and I was done!!!
Thanks guys!!!
08HoeCD
4 each 3/8 clamps
couple zip ties
Thanks guys!!!
BOOM! :thumbsup:
Enjoy.
NeverSatisfied
eBay Baller
Wichita, Kansas
How did you get away with just 4" of hose?
Lol just messing with ya, I'm sure you meant 4' (foot). I thought it would take longer then it did but it was literally 15mins when I did mine lol minus the 10mins I took sealing and tightening the fittings the day before
FatDog
Ha ha...LOL I actually pulled like hell and stretched that 4 inches to work!!! LOL
TejasPitt
