domer94
northwest NJ
layed a little bling on the burb... ive always wanted to put some LTZ wheels and rubber on it,. I finally changed my front lights to chrome / led. and put on some mirror covers. I remember the last Tahoe I had, I put on one of these replacement headlight kits and it was just as annoying. the part looks nice, but there is always some slight fitment issue. I still have to adjust them as well , which is a pain in the ass for some reason. love the look of the extra chrome on the white truck. makes it pop more I think , also with the 20" wheels
Fosscore
Those LTZs look really good on the OBS body style. Nice work.
Gzes
the drifting 2dr
Wichita tx
Gonna go checkout my 2dr and chew out my bud. Been too long with no progress. I want my damn 2dr back!
domer94
northwest NJ
installed a B&I moulded wood trim kit. was very please with the look. ive had those other stick on kits in the past , but this one actually looks like its a moulded factory part. also , the kit isn't overbearing... I think its just enough accent. compliments my new carpet mats. my ultimate plan is to find a denali center console (maybe the unicorn has it in her cave), and the B&I custom wood grain wheel. all the grain will match and the quality will make it look factory.
2doorfiend
Domer, wish i had seen that post a few months ago. I found a denali console in a junk yard in anchorage, alaska! (Well 2, but one i used) and now im down in north carolina. I do, however have the rear cupholder panel to one, but i dont think it has the rear radio putton panel, and one of the tabs are broken (like 80% of the remainders) ill keep my eyes open down here
chaingun427
OBS Mad Scientist
Mooreland, OK
My beater Tahoe's fuel pump gave up the ghost, so I swapped in the one from my ls swap. Looking at options hour pumps compatible with an 88-98 sending unit, but I'm not finding anything but stock
Sent from my SAMSUNG-SM-N920A using Tapatalk
95escahoe
installed a B&I moulded wood trim kit. was very please with the look. ive had those other stick on kits in the past , but this one actually looks like its a moulded factory part. also , the kit isn't overbearing... I think its just enough accent. compliments my new carpet mats. my ultimate plan is to find a denali center console (maybe the unicorn has it in her cave), and the B&I custom wood grain wheel. all the grain will match and the quality will make it look factory.View attachment 63424 View attachment 63425 View attachment 63427 View attachment 63428 View attachment 63425
I love that kit, says it matches the Denali woodgrain too
Czykats44
Dis Member
Glenville, NY
Added an aux for music. I used an FM Modulator (iS-31) came out great, I've used these units on many of my older vehicles.
It works by plugging into your antenna line and adds a signal to a particular freq, I set it to 87.9. You set 87.9 to your favorites, select it and plug in.
I did however break both the hvac control head tabs. I just drilled a hole in the mount and ran some zip ties around.
Sent from my Spaceship.
noJeepshere
Bountyfull, Utahrd
I used a signal box that plugs into the aux input in the back of the radio where the remote tape or cd deck plugs into. It was much better sound than an fm modulator. At least I had that until my factory head unit died and I converted to a double din setup.
sent from a slablet
Czykats44
Dis Member
Glenville, NY
sent from a slablet
I still actually have CDs so I figured I'd use them. I did what you described on a 99 Grand Prix I used a remote cassette from one of these truck and snagged the R and L audo lines for the 3.5mm.
Dneel81
OKC
ripped out my cracked dashboard...I might have bitten off more than I can chew.
Went to the junkyards and pulled a nice uncracked dash....hopefully I can get it put in without cracking it. stupid UV damaged plastic...
95escahoe
How much of a pain is that? Need to do mine
Dneel81
OKC
Brett,
It's a bit scary just for the amount of harnesses and fragile parts on an other-wise heavy piece of equipment. Three screws on the top side near the windshield, bolts on the underside up by the HVAC (5/8ths bolts) and it will lift up and swing out toward the seats. Just disconnect the wires and it's pretty much out. I let the steering wheel down with 2 bolts and it came out a bit easier. I did it by myself, which maybe was a mistake. Getting the new one back in will likely prove more difficult.
95escahoe
Brett,
I see, is yours the dual airbag dash or the 95 single airbag? I need to find a good dash to swap in and make some calls to see how much to get it done, not sure if I want to risk it
99YukonSLT
Ohio
Picked up this bullbar off CL for stupid cheap, basically brand new. Picked up some hella 450's from summit and put a yellow tint overlay on them. My passenger side fender and liner decided it was time to rot away (it's aftermarket) so I picked up a new one and painted it myself to save some $$ and time. Undercoated the liner and will be doing the same to the inside portion of the fender along with some cavity wax to hopefully prevent any further rusting.
Also figured while I was painting stuff to touch up all the other little rough spots around the body. Sanded it all down or wire wheeled it, cleaned, primered, then either painted or used undercoating (wheel arches) to keep the chipping and rusting to a minimum.
View media item 25801
Drewphil
