Z55 suspension question
HACK BLOCK
NYC
my brother has a 2007 tahoe that be bought from someone after an accident so he took it to a shop it have the frame straightened out and body work done. at the same time he converted to standard shocks. at 200k miles his tahoe drives like a million bucks. my 2011 Denali 120k miles z55 suspension feels like shit compared to his. does the z55 suspension go bad over time or is it one a shock blows then replace? is it only cause his is brand new? just recently had the brakes changed so I had the shop look over the suspension and they said everything was fine.
mikeyss
Longmont, Colorado.
Z55 suspension does get old. As the strut/shock wears out, the computer sees this and applies more current to the struts/shocks to maintain what it thinks the ride should be. It basically locks itself up on every bump. When I replaced mine and reset the ALC, it drives extremely smooth and responsive. I also have Eibach front and rear sway bars, Z55 is awesome when it's all working.
H
HACK BLOCK
NYC
is this something I can see or test with a tech 2?
H
HACK BLOCK
NYC
I don't plan on converting simply because it's cheaper. whatever rides better is the way I'm going
mikeyss
Longmont, Colorado.
A tech 2 would be needed.
Short story with mine... I have an 09 Tahoe LTZ and when I bought it, I knew the Z55 components were worn. I replaced it all, BUT..... As I was replacing mine, I did something stupid and blew out one of the new front struts as I was reassembling it. Since it was a weekend, I had to put standard front struts from Napa on so that I could drive the Tahoe home. I had to wait a week to get a new Z55 type front strut. I have to say that was the WORST week I EVER had with driving the Tahoe. The standard shocks just sucked so bad during any type of cornering, and I could feel every expansion joint in the road. I was so happy when I was able to get it all back together with the proper stuff after that week. Other guys say they have good results deleting Z55, but I think it's a good system.
H
HACK BLOCK
NYC
yea I can feel every joint now. my wife even asks if we have a flat tire
H
HACK BLOCK
NYC
what do you think? it's shot?
ya, whatever shop you went to, don't go back......
you can get oem replacements or the arnott replacements for a decent price at rockauto
you might need the airpump as well if it is not working when you turn the key to run.
with those shocks blown out it will ride like shit
H
HACK BLOCK
NYC
the shop actually told me to order them online that it will be cheaper
you said in your first post: I had the shop look over the suspension and they said everything was fine
ivin74
05 NBS Nali
Htown, Texas
@mikeyss
How did you reset the ALC? I have a tech 2 and cannot figure it out
@mikeyss
it's in there I think under "body" vehicle needs to be unloaded and parked sitting level, I just ran the tech2 cable out the drivers window
I think all it does is basically let all the air out of the shocks and waits a second to take a reading at 0 psi. to get a calibration.
it will say in there somewhere "reset trim" probably under special functions.
takes like 30 seconds and it's done.
ivin74
05 NBS Nali
Htown, Texas
It's under the chassis part, then special functions.
Going to try it this week, thanks guys
ivin74
05 NBS Nali
Htown, Texas
@Doubeleive
I don't get that option on my Tech 2, I tried the body and chassis and can't find anything about the suspension.
JeffK
