Which front bumper?
EastTXYukon
Longview, TX
Looking for a new front bumper for the Yukon. I want a fog light bumper, just cant decide on which one.
I like both the diesel bumper with the fog lights towards the center, but I also like the aftermarket bumper that has the round fogs toward the outside of the bumper.
The diesel bumper is cheaper, but I'm worried about mounting up the fog lights since I will have to rig something up. The other bumper is ready to put on with no modification but it's over $100 more expensive.
Let me know which one you prefer and if you have any good ideas on how to mount the fog lights in the diesel bumper.
http://www.lmctruck.com/icatalog/csd/full.aspx?Page=55
http://www.lmctruck.com/icatalog/csd/full.aspx?Page=57
Tbruz
Windham NH
I personally like the stock look and just added the stock bumper mounted fog lights to my 1997 Tahoe 2 door, pics are posted in interior section somewhere.
Ordered up a OEM GM bumper with rubstrip and bumper guard provisions but GM stopped making that one and substituted the GM Diesel bumper w/no rubstrips holes in its place. (It's nonreturnable and sitting in my garage, make you a deal if you decide to go that route.)
Next step was ordering a LMC bumper with rubstrip and bumperguards.
The quality was subpar and I had to have a body shop re-drill the mounting holes but that was cheaper than drilling the GM bumper they sustituted.
During my project I also gathered up a second set of OEM stock fog lights, the OEM discontinued mounting buckets and the OEM discontinued fog light switch; all are listed or sale in the For sale section for $240 shipped
The stock harnesses are still available but not cheap. I can dig up p/ns if you decide to go that route or you can locate aftermarket fog light harnesses on Ebay for about $100
Total cost to install stock set in bumper is about $500 to $600.
Tbruz
Tricky
Illinois
Tbruz, are they working properly? And have pic's?
Sent from my iPhone 4s using Tapatalk.
Tricky
Illinois
Tbruz cool. I thought you would have went with the one like mine.
the big blue bus
richmond, va
fogs in diesel is what id do. i had s10 fog lights in mine. use a piece of flat stock bolt it to the bumper brackets up top and bolted lights to that so they hung down in hole. had a nice pattern for 20 fog lights lol took em out when i put hids in driving lighs on bumer guard i want to swap em back into fogs in bumper the hole open bugs me
Tbruz
Windham NH
Tricky,
I liked the chrome look with the rubstrip and bumperguard;it matches the rear bumper.
BTW, Thanks for your help/input in getting them operating properly, turned out it was burned out leds in both the foglight on position and the dash illumination spot. Replaced both LEDs.
Tbruz
E
EastTXYukon
Longview, TX
Do you know or can you measure the size of flat stock you're using. I'd like to try and gather parts, then buy the diesel bumper as the last thing if I decide to go that route.
Thanks
the big blue bus
richmond, va
Thanks
at first i used some flimsy crap off this old shelving thing i had lol im going to homedepot next week to find some and ill let ya know. i know its got to be as wide as the 2 bolts on the top of the bumper mounting brackets. now this makes the lights sit back in the hole though. let me find picture how it lookd.
bad pic
light pattern from one..
with walmart lights that fill the hole more but not nearly as good of pattern as the s10 fogs. those lights are on my grill gaurd now with hids.
E
EastTXYukon
Longview, TX
So Ive got a line on a diesel bumper, but its a smoothie without any holes. I have to run a front license plate here in TX. Would I be able to drill the license plate bracket holes with a hand drill? Or is this something a body shop could do for me?
Tbruz
Windham NH
Those are just round holes, easy enough for you to do.
Tape the locations on the bumper first then use a center punch and a fresh drill bit.
You should touch up the drilled holes with some paint to avoid corrosion if you worry about that stuff in Texas!
Don't forget to get the proper front plate bracket for a bumper with no rub strip......ask me how I know.....
Tbruz
curbud
