What seals air shocks?
ukrkoz
Auburn WA
Few weeks ago, I was under my truck and squeezed the driver side rear shock bellow. Hissing noise. I assumed, shock bellow is leaking air, called it warranty and received replacement shocks FOC Thursday. Yesterday, I started replacing it - shock is only 8 mths old - and found, that air comes out of the nipple attachment. More specifically, from a plastic elbow, where air line comes out and bends at 90.
I did further investigation and could not determine anything that, actually, seals air on the nipple.
Even if line attachment was made snug on the nipple, air still bleeds from where the line enters into the elbow. There is no seal, O-ring, etc, neither on the nipple nor in the elbow itself. It just loosely clips onto the nipple and that's it.
I work professionally with vacuum sockets and know, what it takes, to seal air bladder.
I sealed that line for good but I have question now. What exactly seals the line connector to the nipple and, it has to be an AIR TIGHT seal, what is, by far, not easy to accomplish on anything, least to say - on an up and down moving shock?
I'll check on the pass side one too but, last time I did it, there was no hissing noise coming out of that one.
U
ukrkoz
Auburn WA
Is there supposed to be a small O-ring inside the connector then, sealing line metal end to the nipple edge? And it got lost, when shop replaced that shock in March?
I think there is a tiny o-ring inside the air line connector but I would need to go look at my spares and verify, you can buy a air line kit and replace that piece if you need to, it obviously works well as GM has used the same design since the 70's or before.
if it is holding air now no need to check the other side as both lines are connected together the a "T" connector, it is not pressurized left/right.
Yes, there is a small o-ring that seals the hose and its 90 degree hose connector to the shock's air connection nipple. You can see them in the photo below, which is a replacement air hose kit for this suspension.
U
ukrkoz
Auburn WA
Ok, I looked at several videos of trouble shooting air shocks and, what I noticed, on various vehicles, nipple, air line is attached to, has a shiny metal tube inside of it.
What exactly is that tube? Air valve? I saw it on Tahoe, Escalade, Suburban air shocks.
j_jerry79
