Well crap...nicked aluminum heater line
mijohnst
In the process of replacing my heater core, I cut out the old heater core lines coming out and thought while I was at it I would also use my oscillating tool to cut off the old plastic heater core connects. Well, I wasn't careful enough and now it looks like I circumcized the end of one of the aluminum tubes that running to the back heater. I doubt without the flare at the end it's going to hold antifreeze.
Ugg... One more thing I didn't want to have to deal with. Any suggestions on how I should fix this? My thought is to go the junkyard and cut off about a foot of the tubing from a like Tahoe and somehow splice it together. I don't think I could braze under there because it's too close to the firewall. Maybe a compression fitting? Will that work with aluminum? Maybe just use rubber tubing to connect the pipes together?
One of these days I'm going to stop making dumb mistakes. :/
mijohnst
mijohnst
No, I didn't cut the heater core. I cut the tip (the flared end) off the aluminum pipe that connects to the rear heater. You can see it in the picture.
wjburken
Eastern Iowa
Oops! That’s definitely more than a nick.
That will not seal, that is for sure.
I am not sure I would try and splice that. The fewer splices/connection the better when it comes to coolant lines. I would try and find a whole replacement line.
oopsie!, yes that lip makes the seal
option 1: replace the line
option 2: cut one off a junker and patch the end piece back on with clamps and a section of rubber hose
mijohnst
mijohnst
I can pull an entire line off of a junker but I think it's going to be a nightmare to pull one out. :/ Isn't it one continuous piece from the front heater core to the back one?
GMT800 2005 Tahoe Z71
Navy Supporting Member
I should have read that closer. Oh boy, what a mess. Still having fun working on your rig? Sorry.
I don't see one listed at RA, GM Parts Warehouse or GM Giant. Salvage yard I think.
The only other way I see it is to run a shunt of sorts. Have to use a length of hose with 2 new barbed splices, one at each end, and run it along the route of the old one. If all that is even possible.
mijohnst
mijohnst
I really appreciate the input from y'all. I don't see how I'm going to be able to replace the entire line in one piece and I can't find anywhere on the web of someone doing that. I think I'll go out to the junkyard and cut a 1 to 2-foot section from the same pipe, cut my pipe at the same length and then use high temp rubber tubing to connect them. I'll bulb the connection ends for a tighter fit and use small hose clamps to connect them. I'm going to try that and see how it works before I re-run that entire line.
Or something I just thought of... maybe there is another type of fitting I can use to connect into the heater core T connector that will allow me to use a small hose clamp instead of the snap-in. Man, that would be nice...
One day I'll learn...
mijohnst
mijohnst
Ok, I think I know what I'm going to try. I've ordered one of these types of connections and I'll just use rubber tubing to connect my original line to that smaller clip-in. Basically I'm still connecting the line with rubber tubing like I planned to do but I won't have to cut my line at all and I'll connect right at the junction.
live2pull
Phoenix, Az
I would cut the end off at the wrecker and compression it on. The trick would be finding the fitting that fits.
mijohnst
mijohnst
I ran to the local junkyard and cut off about 12" piece but how would you compress it on? Thanks for the suggestion!
mijohnst
mijohnst
I would take that piece to a hardware store or auto store and find some high temp hose that fits snuggly over the tubing and a couple of hose clamps.
Great minds think alike. I did that exact thing. I bought high temp rubber tubing that is snug around it with a few small hose clamps. I think it's going to work great. I'll put pictures up when I'm done.
mijohnst
mijohnst
Actually I think that might seal
IIRC the o-ring doesn't seal down that low
File the end flat then taper it so it doesn't pinch the o-ring on insertion
I thought about it but I thought that the bevel needed to push up into the seal. I might try it and if it leaks go my patch route. Thanks for the input!
wjburken
Eastern Iowa
If you haven't cut anything (more) yet, i'd give it a shot. What is there to lose?
Conedaddy
