Water damage to the distributor
mikeykey
hood got left open in the pouring rain for a couple hours. Now, a day later, can’t get it start.
already checked everything i could think of and am not getting anywhere.
checked:
distruibutor for water = negative
Good spark
Good coil
Good fuel pressure (60)
good EFI readings
Fuel on spark plugs after turning it over
Pcm isn’t wet
All connections aren’t wet and are tight
Cam shaft sensor good
Crank shaft sensor good
No codes on computer
Etc….
at a loss for words on the problem. Hopefully over night if it is water damage, it dries out and fixes itself.
any suggestions....
Rcarew907
