Tubular trailing arms!!
X
xjayx
Hawaii
The arms I bought were on ebay and they were Control Arms Lower LCA 64-72 GM A Body Chevelle Cutlass GS 442. There the exact same length as the yukon arms just slightly more narrow.
STORMIN08
similar subject, but slightly different...
i just replaced my rear track bar on christmas eve...the stocker is in the rear of my truck awaiting a day to get accurate measurements...then i will fab one with better joints and make it adjustable to accommodate my rear 1.5" lift. it needs about another 3/8" in length
Xsbank
can someone explain to me the benefits of replacement trailing arms?
Trey Hardy
Eastern North Carolina
Basically their a solid unit that’s a lot stronger then oem and if you get adjustable ones then when you lift or lower your ride you can center your axle with your panhard bar and then continue to adjust the trailing arms for proper angles for your u joint and drive shaft
Thrust
ICT
Any updates since installation? Do they make any noise even with the washers you had to add? How's the ride quality and cornering?
Poppyj
