Truck smells like farts in the morning
RoadHoe
Got a 2013 Tahoe with 119k miles. The last few days I’ve gotten in in the mornings to go to work, the inside smells like farts. But it quickly dissipates when I start driving. Gauges read normal, no warning lights. I don’t recall ripping one so bad recently that it would linger for days. Can anyone think of what the issue could be?
Geotrash
Dave
Richmond, VA
I used to have a Subaru like that. Velour seats. I'd rip a paint-blistering fart pulling into the garage and my ex-wife would complain the next morning when it puffed out of the seat when she sat down. I kid you not. I always wondered why that marriage didn't work out until just this moment.
On these, it could be anything from a water leak to a dead mouse. None of the construction materials are particularly farty.
petethepug
Michael
SoCal
It’s time to add the aftermarket charcoal hvac filter kit under the dash. Sounds like delicious condensation water and dust is fermenting overnight.
When you cut out the factory access panel you can clean it if dirty
j91z28d1
this and maybe turn on afterblow?
mine sits on a incline driveway and if I forget to turn the ac button off a few blocks before the house. the amount of water that pours out when I back out in the morning is crazy. during the less dry days it can smell too. I guess the drain is in the front of the box, unless I back in it holds what looks like a half gal of water in the box.
RichardCranium
Mebane, North Carolina
With a name like RoadHoe, one could guess what might contribute to the smells......
Quite a variance in what it could be, as you see from the drastically different replies here (beyond washing your backside). To me, I read this as a stagnant odor in the interior. Meaning you open the door and get in (without the vehicle running at all), and you get the sense you've 'dutch ovened' yourself. If I'm reading your description correctly, it could be something as simple as a clogged drain for your evap box. If that gets clogged, it will pool moisture and end up smelling like the 2girls1cup video inside. And its only going to get worse as the temperatures go up (if this is your culprit). Fairly easy diagnosis, or a quick check anyways. Just let your truck idle with the AC on, and check to see the evap is draining properly (that infamous dripping, clear liquid you always see underneath a ridling vehicle in the summer).
If it is a clogged drain, you might need to douche the evap box to sterilize that RoadHoe, in a sorts to get rid of the evidence you had the clap. There are some fogging machines out there that will help a lot, for a simple attempt to fix it. We often drilled holes in evap boxes and used a pressurized spray can, filled with diluted Mr. Clean (we used a plug to seal it when done). Several ways to clean the scabies....
Burban22
I’ve heard some YouTube reviews complain that aging GM interiors, especially ones with the fake leather smell like sweat, wet dog, sour smells as they age. I have a 2003 suburban with the fake leather seats and even after shampooing the carpet twice I still have the damp, wet dog sour sweats smell especially after it’s been sitting overnight. I’m in the desert so dampness isn’t a problem. I guess I could Febreze the crap out of the carpet and seats?
I also have a 97 GMT 400 with cloth seats. No odd smells. So I’m blaming the fake leather.
Just Fishing
Can't fix stupid
Utah
Made any enemies?
:jester:
Not saying I ever had the thought or anything, but you can buy that stuff in Jars. :angels2:
I play a lot of "If, then How?!" games with myself.
RET423
A rotten egg smell is usually an 02 sensor sending a false lean signal to the PCM, it tries to correct it by adding too much fuel.
If you disconnect one of the primary 02 sensors and the smell goes away on cold startup then you found the failing sensor; it will turn on the MIL light but it won't try to adjust the fuel with it disconnected.
I would try the passenger side first, if that doesn't make a difference I would reconnect it and try the drivers side the next day
KidWgn
Certified Kid Hauler
St. Louis, MO
I'm just here as proof that fart jokes don't stop being funny as you get older.
Signed,
36 year old man laughing hysterically
Drewphil
