Transmission overheat now dragging
DStockton
I have an 07 Escalade with the 6.2 and my trans got up to around 215 degrees and now when I was driving and it was cooling off it was still at around 200 and it felt like it was dragging kind of. It felt like my back breaks were kind of catching but it wasn't them. I could smell something coming from where the trans is.
Any ideas?
D
DStockton
50k. When I parked it you could smell something burning. And now the fluid is a little dark
InTruckDesign
SW CT,
215* is a tad hot for these 6-spd's, but nothing that would cook your trans oil. How is it now?
GM Customer Service
Michigan
Any ideas?
Hello DStockton,
I understand it is frustrating when an issue occurs with your vehicle and you do not know what could of caused it. In the Owner Manual for the 2007 Escalade, it does state that at 50,000 miles the vehicle should have the automatic transmission fluid and filter changed (pg. 519). Also, that your should always use DEXRON®-VI Automatic Transmission Fluid.
I hope this helps,
Jennifer T,
GM Customer Care
D
DStockton
It runs fine now but I put it in the shop anyways. Haven't heard anything yet.
anton28
I put mine through the reamer doing some heavy duty 4wheeling if you can call it that on a beach. The transmission got all weird on me and was shifting super hard and dragging like yours for about two days and then everything went back to normal. Been a few months now with zero issues.
dizhai
