Transmission help needed!! ASAP.
JRandle
So I changed the transmission oil and filter last night and did step by step like the book says.
Well this morning I get in to go to work and it's making a clanking type noise and I have no clue why..
Sounds more like two pieces of metal sliding on each other.
Anybody have any clue as to what it could be???????
Blazed
Accepting Donations
Did you flush it?
I heard that causes problems..
JRandle
JRandle
I just drained the tranny and pulled the pan and filter off. Then replaced the filter and put the pan back on. Then put tranny fluid in it.
JKmotorsports
Austin, TX
Did you remove the shift cable bracket and possibly didnt retighten it completely?
JRandle
JRandle
Would that make a noise that gets faster as a speed up?
Gzes
the drifting 2dr
Wichita tx
Probably oil not getting into the components until it started and is now lubricating everything correctly again
JRandle
JRandle
I believe this was the problem. I just kept adding fluid as I drove it and stopped. It went away and shifts smoothly now!
Gzes
the drifting 2dr
Wichita tx
Yea because when my ex retard mechanic fired uo my engine in the hoe after 8 years of sitting he didnt properly clean or lubricate it and fried my bearings, cranckshaft and some other internal components...
JRandle
JRandle
Oh damn. Yea my hoe is going just fine for now!
jk6062
