Thinking of lowering my lifted hoe
slipping
Rosamond, CA
99 4dr 2wd I bought used. From what I've found out through searching far and wide about the lift is its a 4" front fabtech lift spindles with 3" blocks in back. It has a 3" body lift and 35" tires. While its been fun having it lifted I'm contemplating dropping it low. Maybe 3/4 or 5/6 drop. Maybe even bagged later on. Obviously I'd have to bring body lift back to stock (where to get parts for that?) And get different rims and tires. What would I look for as far as lowering kits? What's best? What's not? Oh and how much of a pain will it be? Thanks all!
Alex33
to remove the body lift, I'd recommend getting the mounts and bumper brackets from a junkyard and then trying to trade suspension and wheels if you don't want to buy everything new. If you want everything new, belltech is good, so are djm and mcgaughys. A 3/4 will require the least work and still look lowered. a 4/6 or 5/7 is going to require a little more work.
just a couple ideas to get you going.
slipping
slipping
Rosamond, CA
I didn't even think bout junkyard. I was planning on going there to get some ttops for my nonttopped camaro. Thanks man!
jdpber
GOLD MEMBER
The America
also depend on how low you wana go. but a guy on here found and did a thread not long ago. and used blazer k5 i believe body mounts and those gain additional like inch of drop if i remember.. and trading the wheels and tires shouldn't be ******* here.. same with life.. hunt you a LKQ or pick n pull yard and pull the components you want and save even more money. i would order the drop spindles.
here man read this thread.. and do this when you remove the body lift.
http://www.tahoeyukonforum.com/forum/showthread.php?t=39466&highlight=Blazer+body+mount
slipping
slipping
Rosamond, CA
Awesome read, thanks man. I was doing a search and reading everything I can.
slipping
slipping
Rosamond, CA
jdpber
GOLD MEMBER
The America
if yo are going to bag.. PM... YATES.. he can get you everything you will need
yea the K5 body mounts is a no brainer if your droping your truck.. i figured you would want that extra drop.. look forward to seeing it on the ground....
yates ™
Resident Apple hater
Iowa
Only for NNBS SUV's, we have nothing for torsion front ends.
Tyhoe24
