Hey you
- Joined
- Jun 27, 2024
- Posts
- 97
- Reaction score
- 68
I have heard about the fuel nozzle extension on several posts... but not one has said where to find it? Its certainly not in the fuel nozzle door. Anyone?
Learned about the moisture sensor for the wipers, and noticed my wipers are not operating as they should. But I had also placed my easy pass just
below the sensor inside, and after moving it to another location... the wipers are doing what they should. Hope this helps someone.
Tire pressure's... The sticker on the door sill, is the recommended pressure. The tires have a max pressure embossed on the side wall, which is greater than the sticker.
So I am running about 5psi greater than sticker, and 4psi less than max. The result for me is a nice ride with about 24 mpg, but have seen slightly higher than that.
Tire size, I had 18" wheels/tires. Decided to up to 20's, and have not regretted the change. The ride is a little smoother, handling the same, and nicer looking wheels.
Automatic tail hatch operation... the foot kick works great... but it can trigger when least expected and give you a sore noggin if not careful.
I really wish the car had the surround vision backup system. That is something I am considering should I decide to upgrade.
OK, I am done venting... hope everyone had a good 4th.
