Squeaky pass side front suspension
DaveO9
Vancouver, WA
2013 Tahoe LT 4x4. As title says I'm getting an annoying front suspension squeak going over bumps at low speed and, to a lesser extent when steering at low speed. All front suspension components are no more than 1.5 years old/10k miles: struts, sway bar d-bushings and end links, tie rods, hubs/wheel bearings, and upper and lower control arms/ball joints.
Over the last two months I've been working on an engine swap. I think that the squeak is on the pass side only is important, as I did spill some coolant when I was refilling the plastic reservoir above PS fender. Of course, that coolant spilled all over front suspension components. I'm guessing that may be the source of my squeak. So far I've taken a spray bottle of Dawn dish soap and water and liberally sprayed the strut area, especially at the top rubber mating surface. Then rinsed off the Dawn well with the hose nozzle. This has reduced the squeak, but not eliminated it. I've also removed the d-bushings and coated them liberally with silicone grease - this had no effect.
I'm wondering if I should remove the strut as a next step. Clean the upper mount area and coat with silicone grease. Any other ideas or probable culprits to check?
mikez71
What struts did you purchase?
The two times I had squeeks in front suspension (tahoe and sequouia), it was the struts both times.
You could swap struts and see if the noise follows..
DaveO9
DaveO9
Vancouver, WA
I'd open up the sway bar U-bushings and give them more grease.
Did that - no effect. I was hoping that was it, since it's the easiest thing to take care of!
They're Monroe quick struts. You could be right, it does seem to be coming from the strut. I'll probably try my wash thing one more time, then pull that strut. Then I'll decide if I do the clean and grease method I mention, or pull the other one and switch them like you suggest. Thanks!
MillerMan338
