Seat Trim Panel Reinstall Nightmare
S33k3r
Dallas, Texas
There are 5 screws that hold that plastic trim panel in place. They only stick out less than 1/2 an inch beyond the plastic of the trim panel. To get them installed, They have to be lined up with the holes in the seat fram, and the leather and the padding have to be compressed to get the plastic/screw close enough to the frame to screw in. I have spent 3-5 days failing at this task. Does anyone have advice?
I can't get screws to center things in place. I tried centering things with cut coat-hanger, but they won't stay in place, even with silicon sealer. And they pulled out of the silicon sealer before I could get things to line up (the coat-hanger wire is too thin to properly hold things lined up).
Keep in mind that when you sufficiently compress the leather and the cushioning that you can no longer see the back of the plastic, the bottom of the screw, or the frame holes...
I **REALLY** don't want to pull the seat out. And, at this point, I'm not even sure that would really help.
Can someone please offer suggestions -- either on how they've done it themselves, or how they someone else did it?
[EDIT: This is on a 2004 Escalade Platinum, and the driver's seat if not obvious. Thanks again.]
Thanks!
ReaperHWK
Longer screws?
Get someone to assist and compress while you screw?
Get a strap and ratchet around the seat cushion to compress it?
Just quick thoughts.
S33k3r
S33k3r
Dallas, Texas
Longer screws?
Thanks. The compression isn't the issue. It is making sure the holes of the panel and the seat frame are aligned when I can't see the holes of the seat frame.
mikez71
Keeping tension on the screw with the screwdriver, while fishing for the hole doesn't work?
(Dragging the tip of the screw around the frame until it falls into a hole?)
Maybe the foam is throwing off your alignment more than you think..
If you push hard enough to see where your screw tip scratches the frame and adjust your position?
96xr250
