The dreaded flashing Check Engine Light
Motojoe86
Apologize in advance as this is now posted in 2 forums as I was unsure where to post this at. Anyhow, hello guys, I am new to this forum as a member however have been on here a ton to read on issues. Always seems to be a great source for all things Tahoe related. I have read several of your forums regarding check enginelight and am unfortunately creating a new one with hopes there might be more insight. Here goes:
Vehicle:
2003 Chevy Tahoe 4wd z71 with 5.3l flex fuel engine 160k miles
Symptoms:
I am getting a flashing cel whenever i am on the highway over about 70 mph. If i rev it in neutral it will flash being held over 2400 rpms as well. Also, whenever i have it in tow/haul mode it flashes almost all the time. Lastly, towing in regular mode it will flash about 50mph+. It seems to run good minus a very minor stumble in idle (unnoticeable rpmfluctuation) and terrible gas mileage. 2 side notes- i have an srs light on and my alternatoris going out which I am replacing this weekend. I cant imagine these would have any affiliation with cel though would it? It usually doesnt store a code however I have been able to pull random misfire code twice.
Work done to no avail:
-New iridium plugs gapped at .40
-New plug wires
-New coils
-New air filter
-New pcv valve
-Cleaned MAF
-Cleaned throttle body
-Fuel pressure tested within spec
-Seafoam through motor oil
-Crankshaft sensor tested within spec
I am running out of ideas on what to replace and the costs are beginning to add up. Any thoughts or ideas on the culprit would begreatly appreciated. Thanks in advance!!
With what you've spent on it already, you could've had a shop with a scan tool perform some diagnostics and probably had it fixed. There are just too many things that could cause random misfire. Until a knowledgeable tech can watch a real-time data stream while the truck is being driven, you're just gonna continue to throw parts at it and likely waste more money.
The SRS light is unrelated but a faulty alternator could be related. Left to test are MAP sensor, O2 sensors, cat converter(s) and all related wiring.
Motojoe86
Motojoe86
Appreciate the reply. I should have noted that I HAVE had it in to a few different shops with diagnostic checks and hooked up to a tech 2 amd none of them see to have a specific idea of whats causing it. They all have pretty much said they'd throw random parts at it with no guarantee of a fix... Was hoping i might get lucky on here with someone that found a solitary fix. Aside from alternator that im doing this weekend, where would you start first? Thanks for the help!
Scottydoggs
NJ
typically only two things make the cel flash is, needing a tune up real bad, but you got that covered, the other is clogged cats. clogged cats cause? yup you got it, random misfires.
it likely also feels down on power too when wot.
Motojoe86
Motojoe86
Thanks! That was one issue I was afraid of lol. What is tye best way to test cats? Ive heard of a pressure test, temperature test and one other kind... Also, any idea of what a fair price for a shop to test them might me? Thanks!
HiHoeSilver
Away!
Chicago
Pull an O2 sensor and shove a camera down there.
At least you brought it to get scanned. So many DIY-ers avoid paying a professional their diagnostics fees because they feel they're too high, yet spend hundreds or thousands trying to get lucky.
Honestly, I still feel that seeing a live data graph would really help. But, it has to be read by someone that knows what they're looking at and what to look for- not just scan for code(s) and replace whatever sensor the code relates to. A random misfire can be a nightmare to track down, as you're experiencing, and I've seen shops dismiss such cases because it's not worth their time. If they have a flat diagnostics rate of $X, they know they're screwed getting involved with such a problem because they could be on your vehicle for hours and hours when they could be knocking out and getting paid for repairs on multiple other vehicles in that time. I can't say this is what you've gotten, but I had to mention it.
Anyway, there HAS to be something that happens that causes it and a sharp/well-trained tech should be able to pick up on something being amiss (pun intended) in the data stream right before or during those misfires. A MAF reporting some outlandish amount of air (or lack of) at certain RPM, a MAP sensor reporting odd vacuum amounts at certain RPM, a clogged cat converter stopping up the system (although this should cause catalyst efficiency codes), upstream O2 sensor(s) reading awry, the fuel supply being insufficient at the higher RPM... All should present numbers that don't "add up" in the data stream. They may not cause codes to be set, but if the tech knows that, for example, the MAF should not be reading 1,000 g/s at 2,000 RPM, then they would investigate the MAF. Same scenario for the MAP sensor, which is primarily used to calculate engine load by intake manifold vacuum. The PCM adds or removes fuel and timing based on this input in conjunction with the input from the other sensors. If it's erroneously adding a bunch of fuel because it thinks the engine is under 100% load when it's really only at 50% load, that would cause excessive fuel consumption and misfires. It should also cause the O2s to report a rich exhaust and, there again, throw code(s). The same goes for the opposite of perceived load versus actual load and lean exhaust.
As Scott mentioned, check the cat(s). They can be visually scoped through the O2 sensor bungs, have the inlet and outlet temps compared or have the system pressure checked. I know you said the fuel pressure was in spec, but was this with key on/engine off, engine idling, etc.? What about while driving with engine under load? I've had fuel pressures pass tests with the car sitting in the shop, but read low when driving. I'd secure the gauge to the windshield under the wiper with the hose going between the hood and cowl to the fuel rail and road test it.
Motojoe86
Motojoe86
Thank you, a lot of good information. I think I will try the scope of cat and fuel pressure check while driving tomorrow. I imagine a cheap harbor freight fuel pressure gauge would work for the time being? I guess I will go soak my sensors in pb blaster now lol
Sure, I'd use a cheap Hazard Fraught gauge for this. The pressures it reports may not be accurate, but you're looking more for an excessive drop rather than actual numbers.
Motojoe86
Motojoe86
Awesome, im going to give this a try tomorrow. Thanks!
Pepper1700
