Tech2 menu help
S
shegarty
Ya it only does it once and it has to be installed already duh..lol
My bad. Didn’t want to get too far ahead of myself and install the new module before I knew how to reprogram it. Thanks for the heads up.
you won't hurt anything putting it in there, and it won't do the re-learn if there is nothing there to re-learn, the airbag light would just stay on until the re-learn is performed.
I would try and clean up the harness connector as much as possible while you have it unplugged just for good measure, contact cleaner, maf cleaner or something of that nature.
S
shegarty
I already did that with the old one in the hopes that it would help - to no avail. There is a good chance that this won’t fix the problem as the codes are for the front two sensors but given the corroded state of the module case I figured it was worth switching. I’ve already tried swapping the sensors with ones from the wreckers without any luck.
could just be a bad module, only 1 way to find out....without a deep diagnostic dive.
S
shegarty
From the state of it it’s a good place to start. Also, I was able to get a couple for next to nothing and sensors up here are $150+ ea.
kootamcgrabbin24
