Tech2 menu help
shegarty
Finally got a VCXNano up and running and have the unit connecting to the truck to retrieve data. I want to change out the airbag module under the drivers seat due to SRS codes - the unit was badly corroded after the interior floor got wet this winter (hole in the floor has been patched). I have another used unit that I want to change out but I was under the impression that I would have to do a VIN relearn with the new unit after plugging it in. I have navigated the Supplemental Restraint menu on the Tech2 software and I can't find anything of the sort - would it be under the BCM menu or somewhere else?
MassHoe04
Western MA
If you happened to see my initial response, disregard... I misread and thought you were talking about the sensor.
should be under the srs or sdm special features? ignition has to be on I believe not just on accessory. I know it's in there somewhere I have done it
I just did a sensor replacement on my front left for my 04 Tahoe. I have a Tech 2, but didn't have to do anything with it when I replaced the old sensor with the new one. Easy peasy. The computer does "read" the serial number of the sensor and validates the sensor is working when the ignition gets turned on, but I don't believe the sensor has anything to do with the VIN.
he's talking about the module, not the sensor, they have to be vin learned
S
shegarty
I looked in both of those menus with the ignition in position 2 (run) and didn’t see it anywhere
Should be under body and supplemental inflatable restraint
S
shegarty
Ya it only does it once and it has to be installed already duh..lol
My bad. Didn’t want to get too far ahead of myself and install the new module before I knew how to reprogram it. Thanks for the heads up.
you won't hurt anything putting it in there, and it won't do the re-learn if there is nothing there to re-learn, the airbag light would just stay on until the re-learn is performed.
I would try and clean up the harness connector as much as possible while you have it unplugged just for good measure, contact cleaner, maf cleaner or something of that nature.
S
shegarty
I already did that with the old one in the hopes that it would help - to no avail. There is a good chance that this won’t fix the problem as the codes are for the front two sensors but given the corroded state of the module case I figured it was worth switching. I’ve already tried swapping the sensors with ones from the wreckers without any luck.
could just be a bad module, only 1 way to find out....without a deep diagnostic dive.
S
shegarty
From the state of it it’s a good place to start. Also, I was able to get a couple for next to nothing and sensors up here are $150+ ea.
BadDaddy2003
