Tbi to Hmi conversion
Ultimatefit23
I'm rebuilding a 99 5.7 vortec and would like to know if I'd still have to use a computer to set the timing or can I do it the old way "turning distributor by hand". Of course I'm changing the intake as well as add a carb.
randeez
south florida
You'll need to swap to a points style distributor to adjust timing that way. The stock distributor adjustment is only used to "sync" it up with the crank position. And spark is computer controlled
I think 99 vortecs used a 0411 ecm. It's pretty easily tuned iirc. Not to question your skillset, but more or a generalization of what I see here and a few other boards. Guys jump in and say they're sick of that computer junk...a week later they're trying to get help tuning a carb. If you're going to have to learn how to tune it either way you go, learn the efi. Tuning carbs sucks, swapping jets, pump cams, idle screws, drilling out plates, realizing you have the wrong size jets and then having to start all over tearing the carb down.
If you know what the engine wants it's just a couple key strokes to make the same changes
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
So you want to use an HEI ignition with vacuum and mechanical advance along with your holley. That would work in an old school way. You will be able to set the timing by turning the distributer but you will need to add the correct components such as a pointer and a mark on the balancer to have timing marks to use.
Please tell is more about your project so we understand what you are trying to accomplish.
U
Ultimatefit23
I just want to take my 5.7 add a few performance upgrades to it.
Lt4 hotcam
Ls6 springs
1.5 roller rocker arms
650 cfm Holly carb
Haven't decided on the intake manifold
Hei distributor
I understand about the pointer and mark on balancer. Thanx for the reminder though, it did kind of slip my mind. This is my first solo build so I'm just looking for help along the way.
George B
¯\_(ツ)_/¯
Lt4 hotcam
Ls6 springs
650 cfm Holly carb
Hei distributor
So you want to delete the ECM and fuel injection. Moving to a carb and HEI distributor. I suspect because it seems to be the easiest way to gain power?
Knowing this, in my opinion you would be better to stick with the computer control and fuel injection and either have it tuned or learn how to do it with EFI Live or HP Tuners.
On a a personal note, If I had the time in life now I would be learning how to use EFI live. Would be a nice little side business
U
Ultimatefit23
I agree with everything you said, and to be honest I do have the time to learn the tuning process. Money wise what would be the cost involved in tuning, as opposed to the swap in question. And what would I need to get the process started
George B
¯\_(ツ)_/¯
This will be a question some others can help with.
liquify33
Houston
FWIW, HP Tuners has a “repository” of tunes, hot cam and L31 is a common one and should get you in the right ballpark. These are free with registration. HPTuners community is not big on the Vortecs, more of an LS crowd though.
That said, I believe BlackBear uses EFILive and can mail you tunes based on logging you send to them. If you don’t have a tune shop around I’d go the black bear route personally.
I inherited an HP Tuner setup with 1 license left and it’***** or miss. Crank relearn function just crashes the software and resets my radio for instance but the diagnostics and real time data are amazingly helpful at times.
drakon543
besides getting a tune everything you can do with a carb setup you can do the same exact thing with your current setup. only real difference is with a carb setup once you have it dialed in you never touch it. with tuning you can have varying levels of power and drivability with the push of a button if you wanted. unless something is broken on the truck pushing this decision i highly suggest keeping the stock setup and working from there. plenty of information here and if you can't find the information ask someone will answer. also do a forum search for blackbear they are the go to source for tuning here. i also haven't used them but with as many people here that actually recommend them they have to be doing something right.
U
Ultimatefit23
Nothing is broken. I pulled the engine to do a complete rebuild and get body work and paint done to my 99 yukon. I more then likely will stjck with the tbi wss just kicking the ball around about the swap. As for Blackbear, I'm definitely going to do some research about them. Off the top of your do you know anything about their prices.
drakon543
not off hand no but ive never had a problem surfing thier website. they are a registered vendor here and their website comes up pretty quick with a Google search blackbear performance. also noticed you used the abv tbi there so just making sure its not a typo. first was the carburetor then chevy moved to a tbi unit which stopped in the tahoes in 95 i believe. 96 on had a tb but had mpfi injectors are hidden under the upper intake. big dependability increase along with more power.
U
Ultimatefit23
It was a typo, I have the spider injectors.
briannorris
