Stuffed 35 12.5's with only 2.5/1 spacer lift
01Konvict
Boats n Hoes
Raleigh/SML
Yeah that offset works for clearance. I was thinking you were on stocks but then I looked at the pic ha. Yeah the bumper corners are a pain! The pro comp brackets are the best for fixing it leaving clean lines. I plan to do a write up on it soon.
Z1500
Z1500
And now for the semi- recant. With my aggressive trimming I've got no rubbing in normal street driving, around corners, over speed bumps and intersections. BUT yesterday I took it out offroading. When going up and down steep grades with big ruts that really flex out the suspension, the rear tires are stuffing right into front of the wheel wells. I had done no cutting in the rear but clearly when compressed, the rear tires pivot forward toward the front of the Hoe.
Any idea if I can trim that area out or re-mount the wheel wells there? My other though is to lengthen control arms a little to move the axle back.
01Konvict
Boats n Hoes
Raleigh/SML
They make longer arms but it's not really going to help any since you need a true suspension lift to gain travel. Think spoon makes some adjustables and I know fabtech makes longer ones for a 6" kit
jdpber
GOLD MEMBER
The America
yes Spohn makes adjustable rear arms.
I think that it would be helpful to many people if you had some pictures of the extent of the front well trimming that was needed and some lock to lock clearance pictures at the outer anac inner corners of the wells. people like me like things like this
TheAutumnWind
People like me also like these things
Looks great!
Jsimon
