Steering wheel swap
Tron843
Hey I have an 06 Yukon Denali and wondering if I could swap in a newer (08-09) escalade steering wheel and use same year denali airbag with minimal headache or is it even possible at all
BatsTDK
Orange County, CA
Going to make an assumption here and say no. Even if they physically bolted on, it’s very likely the airbag wouldn’t wire up properly, and you’d lose your steering wheel buttons and probably horn too.
adventurenali92
Big Bear Lake, ca
I believe the spline on the shaft is completely different where it mounts to the steering column for the gmt900 steering wheels. I don’t think it will even bolt up to your 2006’s steering column.
S33k3r
Dallas, Texas
Keep in mind there was a change in computer protocols in 2007, if I remember this right, so electronics from GMT900 generally don't work with GMT800.
Momoney
Hi
I have a 2008 Yukon xl. I wanted to swap the steering wheel it with a 2013 heated Escalade. Thoughts ?
BlacktopBandit76
